fuel line front to rear https://www.ausmini.com/forums/viewtopic.php?f=2&t=75141 |
Author: | mini bug [ Mon Jan 23, 2012 6:26 pm ] |
Post subject: | fuel line front to rear |
What would be best type of fuel line to use for replacing the fuel line from front to rear on a mini . I need to replace the fuel line from 1/4 inch to 5/8 inch and also run a return line to the tank. Would copper tubing work ? How much tubing would I need to do it? |
Author: | drmini in aust [ Mon Jan 23, 2012 6:51 pm ] |
1. Do not use copper for fuel or brake lines, it work hardens with age and vibration, then cracks. 2. Surely you mean 5/16", not 5/8"... ![]() 3. I bought 4M of aluminium coated? steel tube off a roll at Robbos Spare parts years ago, I dunno who has it now. It bent pretty easy. Try someone with brains, like not Supercrap... |
Author: | Kennomini [ Mon Jan 23, 2012 7:16 pm ] |
Is it called "bundy tubing" different to what doc said but it is good for fuel. |
Author: | TheMiniMan [ Mon Jan 23, 2012 7:53 pm ] |
yeah i normally use Bundy tube & then use a sheath of fuel hose over the top of that,,, keeping both ends outside each front & rear fire walls,,, that way even if somehow the bundy tube cracks/snaps/tears the fuel still can`t get into the cabin Repco sell rolls of the tube & rolls of fuel hose |
Author: | dodge [ Tue Jan 24, 2012 6:33 am ] |
stainless tube 304 annealed tube a few doillars a mrt, can be bent by hand too |
