Steering rack U-Bolts. Tips? https://www.ausmini.com/forums/viewtopic.php?f=2&t=75146 |
Author: | bnicho [ Mon Jan 23, 2012 10:21 pm ] |
Post subject: | Steering rack U-Bolts. Tips? |
I removed the knackered rack from my Moke today and I have the new one sitting in place. I'm struggling to get the u-bolts to slot into the bodyshell. The Subframe mounts are all undone and the drivetrain and subby is sitting about 2" away from the body. Any suggestions to getting the u-bolts in without removing the subframe completely? Cheers, Brett. |
Author: | mini_mad_matt [ Mon Jan 23, 2012 10:54 pm ] |
I had a real job of getting those back in just the other day. I tried levering the subframe this way and that, but i think the succesfull position was when i levered the subframe forward. I did this by levering in between the body of the car and the tower of the subframe. I believe that was when i had success of getting the u bolts in, but i was quite frustrated at the time so i may be remembering wrong. |
Author: | drmini in aust [ Tue Jan 24, 2012 6:32 am ] |
They tend to open up after tightening so the ends are spread when removed. Squeeze them a little in a vice and try them in the holes first, from inside the car- then they will go in pretty easy. ![]() |
Author: | michaelb [ Tue Jan 24, 2012 12:57 pm ] |
Quote: Squeeze them a little in a vice and try them in the holes first, from inside the car- then they will go in pretty easy
I agree, did this last week and u bolts went in easy once they are "squeezed" to line up with the holes. I guess they came out so they must go back in, but you shouldn't have to drop the sub-frame out altogether. |
Author: | bnicho [ Tue Jan 24, 2012 1:44 pm ] |
Thanks guys, managed to get them back in after a bit of squeezing. ![]() |
