It is currently Wed Aug 06, 2025 1:48 am
 Post subject: white smoke
PostPosted: Tue Jan 24, 2012 9:25 pm
so this has ben going on for a few weeks so basicly when the car is at running temp it smokes white smoke out the rocker cover breather and if u sit at driving light it comes into the cabin what would be causing this any ideas???
PostPosted: Wed Jan 25, 2012 6:56 am
Mods rock!
If - and that is a big IF - it only happens when idling, it could be gummy rings from using crap oil or not changing your oil.
Get some quality name brand Diesel (lube) Oil, change your oil and filter. Run with that for about 500 km. Change Oil and filter again for something decent.
If that don't work, then time for a re-bore, new pistons and rings.
PostPosted: Wed Jan 25, 2012 7:01 am
White smoke... Burning water? Head gasket? How's the car running?
PostPosted: Wed Jan 25, 2012 3:14 pm
yep, no rings left... when mine did that (prior to the necessary rebuild), I had a bit of garden hose redirecting the smoke under the car so it wasn't stinking me up so bad. Someone stopped me at the lights and told me the car was on fire :lol:
PostPosted: Wed Jan 25, 2012 6:48 pm
Got a brake booster?
Topping your brake fluid up much?
:P :P :wink: :?:
Edit! :oops:
Bugger; I thought he meant the exhaust! ^^^What they said! ^^^
Note to self don't drink and post... hic! :lol:
Sir Alec! we are not worthy!
PostPosted: Wed Jan 25, 2012 9:22 pm
car is running perfect and i give it regular oil change and use good oil and the engine is not that old
PostPosted: Thu Jan 26, 2012 4:28 am
Mods rock!
From you first description it does sound awefully like burnt Oil smoke from the rocker cover. If the engine is fresh and you say you're using a good (suitable?) oil, then the bores are likely glazed.
What oil are you using?
PostPosted: Thu Jan 26, 2012 7:15 am
that valvoline xld i think it is
PostPosted: Thu Jan 26, 2012 10:16 am
dad didn't run his engine in properly after I did a quick rebuild on it, glazed the bores and used to pump oil smoke out of the exhaust. Once I told him to stop being a wuss and drive it properly, the smoke went away.... but that was a lot different to mine where I had a chimney under the bonnet
oil control rings stop the oil coming up, and compression rings stop the explosion going down.... if you've got explosion gases going down, then guess what
$9 from supercrap, right?
I reckon that stuff is rubbish. My mate was using it in his motorkhana car, and it turns to sludge in his sump between events
