It is currently Wed Jul 30, 2025 1:45 pm
PostPosted: Mon Jan 23, 2012 10:21 pm
I removed the knackered rack from my Moke today and I have the new one sitting in place. I'm struggling to get the u-bolts to slot into the bodyshell. The Subframe mounts are all undone and the drivetrain and subby is sitting about 2" away from the body.
Any suggestions to getting the u-bolts in without removing the subframe completely?
Brett.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Jan 23, 2012 10:54 pm
I had a real job of getting those back in just the other day. I tried levering the subframe this way and that, but i think the succesfull position was when i levered the subframe forward. I did this by levering in between the body of the car and the tower of the subframe.
I believe that was when i had success of getting the u bolts in, but i was quite frustrated at the time so i may be remembering wrong.
PostPosted: Tue Jan 24, 2012 6:32 am
They tend to open up after tightening so the ends are spread when removed.
Squeeze them a little in a vice and try them in the holes first, from inside the car- then they will go in pretty easy. :wink:
PostPosted: Tue Jan 24, 2012 12:57 pm
I agree, did this last week and u bolts went in easy once they are "squeezed" to line up with the holes.
I guess they came out so they must go back in, but you shouldn't have to drop the sub-frame out altogether.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jan 24, 2012 1:44 pm
Thanks guys, managed to get them back in after a bit of squeezing. 8)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
Users browsing this forum: fuzzy-hair-man and 103 guests
