It is currently Wed Aug 20, 2025 8:28 pm
PostPosted: Fri Jan 27, 2012 11:30 am
Online
Could someone please confirm what the correct installed position of the dissy drive is at TDC with 1 on comp stroke.
Two manuals I have seem to contradict one another.
The Leyland manual (black book) says that the illustration (shown below) is the position you need prior to inserting and rotating the drive.
It says to hold the spindle in position shown in Fig A.8 and enter the gear.
The SP manual shows the same illustrated position but states it shows the installed position.
Or perhaps someone could confirm approx where the rotor arm should be pointing at TDC (comp on 1). Mine seems to be at about 1 o'clock.
The reason I ask is that I suspect my dissy is wrongly oriented. Last time I bought a set of leads that were custom length for a mini they were all over the shop.
PostPosted: Fri Jan 27, 2012 11:35 am
That pic is the way it should point when installed, AFTER you have rotated the engine 1 full turn from lining the timing dots up.
If you don't turn it 1 turn, the dizzy will be 180° out.
Manuals do not mention this.
It is a glitch in all the workshop manuals, because they all just copied the BMC original (which was wrong).
PostPosted: Fri Jan 27, 2012 11:47 am
Rotor should be pointing at (roughly) 1-oclock with engine at TDC 9firing stroke on Number 1 cyl)
that means the # 1 piston is at the top,,, the timing marks on the flywheel should have the pointer at the 1/4 mark,,, & the valves on number one cyl should both have clearance,,, & the valves on #4 cyl should be "on the rock" (one is half open & the other is half closed)
that`s it,,, many things there for you to absolutley make sure you have it set-up correctly, so you really can`t stuff it up hey?
Now,,, in saying all that,,, sometimes i`ve seen dizzys have been ripped apart for re-newal/reco/clean-ups etc & they have been put back together one-eighty (180deg) out, so even tho the engine could have been set-up correctly,,, once "that" dizzy goes back in the hole you are now 180 out
get it?
Some people do`nt realise that there are 2x shafts inside the dizzy & once ripped apart they can be set back up 180deg out
Not saying that yours is that way,,, just saying that it can be a catch for the un-initiated :-)
Soooo,,,, whether your "Drive" shaft is set-up right or not,,, you may still have trouble with the rotor pointing the right way (or not) once the dizzy is fitted & this may well be the reason
Got it???
PostPosted: Fri Jan 27, 2012 11:58 am
I'm going to print this thread out and staple it into my manual. Every engine I've assembled has come out with the distributor 180° out!
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Jan 27, 2012 12:20 pm
Online
Yes thanks Guys. Matt thanks for that I double checked and made sure I am at TDC with 1 all closed and 4 "on the rock".
Ok here is a pic of my spindle (hard to tell but the large offset is to the left).
So comparing with the manual's illustration it seems my drive is anti clockwise to where it should be.
Could that mean it has been installed 1 tooth out?
PostPosted: Fri Jan 27, 2012 12:24 pm
Yes it is but as long as dizzy body is anticlockwise by the same amount it's no biggie.
PostPosted: Fri Jan 27, 2012 1:04 pm
what's a distributor drive? I don't think I have one of them....
PostPosted: Fri Jan 27, 2012 1:05 pm
Online
Ok cheers Doc. I understand it's not a big deal but last time I bought a nice set of leads specifically tailored for mini I had to trim them to make them fit neat.
...and I'd probably be in the same boat with an original dissy and/or lead set, the lengths would be out.
So I basically was trying to figure if it was actually correct or not.
Thanks heaps.
PostPosted: Fri Jan 27, 2012 1:07 pm
If you do feel the need to fix it make sure you don't drop the drive into the gearbox.
PostPosted: Fri Jan 27, 2012 1:43 pm
Online
Yes, thanks, I know. I need to use a long 5/16 bolt correct?
Do I need to unbolt the distributor housing from the block first before extracting the drive?
PostPosted: Fri Jan 27, 2012 1:47 pm
yes, and yes
the best bolts are the long ones that go through the engine mount thing on the radiator end of the gearbox.... basically you can't use a bolt that's too long for the job, but you can definitely use one that's too short
PostPosted: Sun Jun 16, 2013 2:25 pm
Online
yes, and yes
I'm nearly ready to swap distributors and fix the out of position drive at the same time.
I don't have any spare engine mount bolts so I looked at Bunnings but they only have long 5/16 bolts in UNC not UNF. I assume I would need a UNF one.
Any suggestions where to find a suitable bolt?.
PostPosted: Sun Jun 16, 2013 2:48 pm
You could just make sure 1 of the engine mount bracket bolts are tight and take the other one out.
I'm pretty sure they are the only suitable bolts you will find on the whole car
PostPosted: Sun Jun 16, 2013 3:29 pm
You can also use the 5/16" rocker studs (the long end ones).
PostPosted: Sun Jun 16, 2013 5:58 pm
hydrolastic top tower bolts ;)
or go to a bolt shop, or weld a bit of rod on to a short bolt
Users browsing this forum: Bing [Bot] and 302 guests
