phillb wrote:
phillb wrote:
phillb wrote:
Look for a loose wire or bad connection on either side of the coil. I have given up using spade lugs there, they seem to work loose. All my coil connections are now screwed on terminals.
Also check the connections inside the dizzy. A Pertronix dizzy I bought had a stripped thread where the top plate screws onto the body, it gave similar symptoms to those you describe. I fixed it with a longer screw.
Ok Cheers Doc I'll check it out.
Wires to the Dissy Module are screw on, ign wires are spades, all seemed tight, plate seems OK. Going to take it for another drive and see how it goes.
New plugs seems to have cured issues. Timing light now working too. Looked at the old plugs and gap was too large. Must have used the wrong gauge ...note to self wear glasses
Is it possible the timing light would not fire is a spark does not occur at the plug? Maybe thats the reason the timing light was playing up.
I'd still like to test the coil. Does anyone know what the readings should be for a GT40 if I bench test it with a multimeter?
GT40 also seems to be NLA also according to Repco.Cheers
GT40 has been replaced by the GT40T. It's a potted epoxy filled one, now made in PRC. They were made here, but had a poor reliability record particulaly with Mini racers.
[edit] the GT40R is now a GT40RT as per comments above.
If you want an original `oil filled' GT40 or GT40R, try Robbos Spares at Blacktown. I bough one there recently, nobody else had stock. $60 though...
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
