Heater Tap for Leyland Mini https://www.ausmini.com/forums/viewtopic.php?f=2&t=75210 |
Author: | Petesmini [ Sat Jan 28, 2012 10:33 am ] |
Post subject: | Heater Tap for Leyland Mini |
Hi folks, Been working on the brick over the holiday period, just have a minor question. Has anybody replace their heater tap on the heater?. If so what did they use?, I trying to stay original as possible,....., would this item be compatible? as far as I can see it would require the lever mechanism to be re orientated? All thoughts gratefully received. At the moment I have plumbed both hoses direct to the core. http://www.rarespares.net.au/rarespares ... uct=HT2001 Cheers Pete. |
Author: | Bubbacluby [ Sat Jan 28, 2012 11:19 am ] |
As far as i know they are the same. Morris 1100 will know for sure. but im like 95%certain they are |
Author: | GT mowog [ Sat Jan 28, 2012 11:34 am ] |
Yeap, that is them. |
Author: | michaelb [ Sat Jan 28, 2012 12:33 pm ] |
I used one of these this week Overnight delivery from rare sPares was very good service Yes I used the old tap as a guide and changed the orientation of the cable connection I also needed to use the metal guide from the old tap as the dimble was the wrong way around But once you sit both taps side by side you will work it out |
Author: | 123grosso [ Sat Jan 28, 2012 5:38 pm ] |
I just had a look at a few falcon spares websites that my mate gave me, turn out the rare spares one is the cheapest |
Author: | wild_willy [ Sun Jan 29, 2012 7:18 am ] |
Or try this http://www.ausmini.com/forums/viewtopic.php?t=44289 |
Author: | Petesmini [ Tue Jan 31, 2012 5:01 pm ] |
Hi Folks, Thanks for all your replies. I now can order the part with a bit more confidence. Once again thanks everybody. Cheers Pete |
Author: | Petesmini [ Wed Feb 01, 2012 5:31 pm ] |
Hi Folks, Now the tap question is sorted. I have another question that relates to the Heater...., The pedal box ducting that runs from the RH side to the Heater. Where to get some? ![]() ![]() Cheers Pete |
Author: | PommyRich [ Fri Jun 15, 2012 9:29 pm ] |
website called purple pig has all your piping needs! Rich |
Author: | drmini in aust [ Fri Jun 15, 2012 10:30 pm ] |
http://www.purplepig.com.au/www/content ... 75&fid=782 Their product is good and their service fast. I bought 1/2 a metre to do my `matic heater + a spare bit. |
Author: | SteveOB [ Sat Jun 16, 2012 10:19 am ] |
how much was that pipe Kev? if ya don't mind me asking I'm after some of the hose for the Mini-Matic heater to the firewall too is it the one around 100mm in diameter? |
Author: | drmini in aust [ Sat Jun 16, 2012 10:30 am ] |
SteveOB wrote: how much was that pipe Kev? if ya don't mind me asking
I'm after some of the hose for the Mini-Matic heater to the firewall too is it the one around 100mm in diameter? It was 83mm, black, I think cost was $30 for 0.5M long, including freight (they posted it from Rocklea branch, in Qld). |
