oil cooler
https://www.ausmini.com/forums/viewtopic.php?f=2&t=75279
Author:  ricksmini [ Tue Jan 31, 2012 7:20 pm ]
Post subject:  oil cooler
hi all just a silly question, Where do most people mount there oil cooler and what sort? pics would be great.
Author:  74snail [ Tue Jan 31, 2012 8:11 pm ]
Unless your going to race/ rally etc etc the car you dont,t need a 10 or 13 row oil cooler
One like this is much better
http://www.ebay.com.au/itm/230681555576 ... 1438.l2649
Karkraft sell the 1/2inch BSP fitting kit with hoses
or as Dr Mini / Mr Green has said before make your own fittings , read his post here
http://www.ausmini.com/forums/viewtopic.php?t=74515
contrary to what I posted in that thread about the thermostat , it would be much better to have it set up that the oil only only flows into the cooler once it reaches a certain temperature or it will clog very quickly , yes you can remove it and flush with kero but you don,t want to be doing it all the time
Author:  IndigoBlueCooperS [ Tue Jan 31, 2012 9:41 pm ]
The photo shows how the common Ausi Cooper S one is fitted. This is in a Deluxe front end.
Author:  Bubbacluby [ Tue Jan 31, 2012 10:03 pm ]
The GT had a special bracket that cooler bolted to and then bolted to the body.
But if its for a cluby, just get a couple bits of flat bar and drill some holes in it and bolt one end directly to the subframe and the other end to the cooler. Thats how i had it done in my leyland mini s
