It is currently Sat Aug 16, 2025 10:53 am
PostPosted: Wed Feb 01, 2012 6:52 pm
We have removed a couple of engines now one out the top and one out the bottom.
Out the top was a bit of a nightmare we didnt have the correct lifting bracket so the engine sat too level.after a few hours of swearing and wrecking stuff we got it out.
The one last night was a donor car with good everything attached to the subframe so we pulled out the front subframe and was a much easier task with less swearing :lol: Only bad bit was lifting the body off the subframe but bonus it was a smashed shell.
So im sure theres guys who have removed 100s so whats the best way and any good tips youd like to share.
PostPosted: Wed Feb 01, 2012 6:55 pm
Use the right bracket with offset, and lift out the top.
More so if it's a hydro car. :wink:
PostPosted: Wed Feb 01, 2012 7:00 pm
They come out the top.
Leave as much on the motor as you can.
Takes about an hour without power tools.
PostPosted: Wed Feb 01, 2012 7:11 pm
cheers for reponses 8) Another question i have is the van has a different drive shaft setup to the donor engine.Van has U bolts and donor has the hex shape joint.
also has new front end stuff and disc conversion so thats all going in.I will attempt dropping the body on the new subframe but sounds like i will probably end up pulling it all apart.
Users browsing this forum: No registered users and 334 guests
