Engine out the top or out the bottom? https://www.ausmini.com/forums/viewtopic.php?f=2&t=75305 |
Author: | KPV [ Wed Feb 01, 2012 6:52 pm ] |
Post subject: | Engine out the top or out the bottom? |
We have removed a couple of engines now one out the top and one out the bottom. Out the top was a bit of a nightmare we didnt have the correct lifting bracket so the engine sat too level.after a few hours of swearing and wrecking stuff we got it out. The one last night was a donor car with good everything attached to the subframe so we pulled out the front subframe and was a much easier task with less swearing ![]() So im sure theres guys who have removed 100s so whats the best way and any good tips youd like to share. |
Author: | drmini in aust [ Wed Feb 01, 2012 6:55 pm ] |
Use the right bracket with offset, and lift out the top. More so if it's a hydro car. ![]() |
Author: | Morris 1100 [ Wed Feb 01, 2012 7:00 pm ] |
They come out the top. Leave as much on the motor as you can. Takes about an hour without power tools. |
Author: | KPV [ Wed Feb 01, 2012 7:11 pm ] |
cheers for reponses ![]() also has new front end stuff and disc conversion so thats all going in.I will attempt dropping the body on the new subframe but sounds like i will probably end up pulling it all apart. |
