Lower control arm bushes
https://www.ausmini.com/forums/viewtopic.php?f=2&t=75306
Author:  poeee [ Wed Feb 01, 2012 7:01 pm ]
Post subject:  Lower control arm bushes
What do you like? I had a look at what is available and now I'm confused.
Author:  drmini in aust [ Wed Feb 01, 2012 7:04 pm ]
IMO the lurethane ones are all rubbish for a road car. They either crack up or flow out of shape. I use the original compressed live rubber ones, never had a problem.
Author:  sgc [ Wed Feb 01, 2012 7:09 pm ]
From memory, there are two types - tapered and parallel, one for early cars and the other for later. Can't remember which is which :roll:
Author:  poeee [ Wed Feb 01, 2012 7:13 pm ]
Early ones are flat.
The standard ones for the tapered bottoms don't have a lip, but other ones do?
Author:  sgc [ Wed Feb 01, 2012 7:25 pm ]
Yeah, I think that's right. The ones I got with my adjustable lower arms were like little barrels, with steel inner sleeves. No outer lip.
Author:  poeee [ Wed Feb 01, 2012 7:42 pm ]
Barrel, that's a great way of describing them. They are the standard ones for the taper type later lower arm. I'll just get them again I think. I put them in the Moke.
Author:  GT mowog [ Wed Feb 01, 2012 8:39 pm ]
As an alternative to (crappy) Urethane ones, there are hard rubber (real rubber!) ones available for the post 68 cars. They still have the steel insert too.
Author:  wobbles_55 [ Wed Feb 01, 2012 8:47 pm ]
Convert them to a spherical bush.... the centre of a rod end! It is easy to do!
Author:  drmini in aust [ Wed Feb 01, 2012 9:19 pm ]
I believe illegal for road use. But fine on the track.
Author:  wobbles_55 [ Wed Feb 01, 2012 9:27 pm ]
Adjustable arms are as well... but this conversion is very easy to hide with factory arms!
Rob
