It is currently Mon Jul 21, 2025 11:57 am
 Post subject: Float level
PostPosted: Sat Jan 04, 2014 2:59 pm
What is the correct float level measurement for the all nylon float? Distance between float and underside of lid with lid inverted? And what does the delrin needle look like?
Should I follow the details I got from Midel?
 Post subject: Re: Float level
PostPosted: Sat Jan 04, 2014 3:08 pm
I think the old rule of thumb is to put a 3/16th drill bit underneath the outside end of the float to give you a level measurement .
PostPosted: Sat Jan 04, 2014 5:34 pm
Does that remain the same with the fixed nylon float as I remember that was the measurement with the float with the metal arm.
PostPosted: Sat Jan 04, 2014 7:06 pm
Sorry Hanra i probably jumped in a bit quick , i just had another look at your pic and realised what your float was . Hopefully someone can help out .
PostPosted: Sat Jan 04, 2014 7:26 pm
Gap should be 0.125 to 0.1875 inch (3.17 to 4.76mm) for the float in your picture. Have the weight of the float only resting on the needle. Can be adjusted be adding of removing washers or gaskets where the seat screws into the top.
1963 Morris 850
PostPosted: Sat Jan 04, 2014 11:10 pm
Which needle is meant to be used with this type of float?
PostPosted: Sun Jan 05, 2014 6:56 am
Dunno....but I would steer clear of any material that looks a bit soft or rubbery (supposedly to stop them bouncing) ...they tend to make the needles stick with gummed up fuel
PostPosted: Sun Jan 05, 2014 8:01 am
The bottom needle is the current replacement type. It's what I used in my twin SU's when I rebuilt them. I have the same floats as your first picture.
I'm not sure about the top needle in your picture.
1963 Morris 850
PostPosted: Sun Jan 05, 2014 9:45 am
The top needle has a small spring loaded ball where it contacts the float. This can be depressed inwards. I note the description for setting the float level it describes the float is "not depressed" made me wonder if it should e running the top needle type. As you can't exactly depress the bottom needle.
Users browsing this forum: No registered users and 66 guests
