Flywheel threads stripped? https://www.ausmini.com/forums/viewtopic.php?f=2&t=75465 |
Page 1 of 2 |
Author: | harry33 [ Mon Feb 13, 2012 8:16 pm ] |
Post subject: | Flywheel threads stripped? |
Hello, I went to remove my flywheel this evening, but none of the three holes in the flywheel for the puller bolts have threads. I can see what looks like the remnants of some threads in the holes, so I assume they have indeed been stripped (rather than there being some other threaded holes behind the flywheel that the bolts are meant to screw into, or something like that - please correct me if this is actually the case!). Any suggestions as to what I should do about this? Cheers, Harry |
Author: | drmini in aust [ Mon Feb 13, 2012 8:58 pm ] |
If it is a 2 piece flywheel, you are looking at the holes in the flywheel hub. The threads are in the flywheel itself, behind the hub. You need longer bolts maybe. ![]() Threads are 3/8 UNF, put a bit of oil on the bolt threads. |
Author: | harry33 [ Mon Feb 13, 2012 9:26 pm ] |
Here's a picture (sorry about the lack of focus).. ![]() I can see right through the circled holes to what I assume is the clutch plate (something solid without any holes in it, at least), and there's no thread anywhere in the holes. Am I missing something? Cheers, Harry |
Author: | simon k [ Mon Feb 13, 2012 9:29 pm ] |
yep... there should be threads in those holes bugger! gentle(ish) taps through the starter motor hole with a piece of wood - tap tap tap, turn the flywheel, tap tap tap, turn, etc. etc. |
Author: | drmini in aust [ Mon Feb 13, 2012 10:09 pm ] |
Get a 7/16 UNF tap, cut new threads, use 7/16" bolts. Tapping drill size is 25/64" but if stripped now it's at least 3/8" (24/64) so is pretty close. |
Author: | Convertible Mini [ Tue Feb 14, 2012 6:45 am ] |
Post subject: | No Threads |
And if it comes off and you intend to re use it get it Balanced or throw it away! |
Author: | Mike_Byron [ Tue Feb 14, 2012 9:41 am ] |
If you need another flywheel I would have one you can have - you just have to come and get it - halfway between Wellington and Gulgong. Mike |
Author: | bnicho [ Tue Feb 14, 2012 11:05 am ] |
I had one like that. A good mate welded a nut on there and we got it off with the puller that that way. It went to scrap metal afterwards. |
Author: | drmini in aust [ Tue Feb 14, 2012 11:48 am ] |
If you are welding nuts on there, DON'T use it afterwards.. cast iron does not like being arc welded.. ![]() |
Author: | bnicho [ Tue Feb 14, 2012 11:52 am ] |
drmini in aust wrote: If you are welding nuts on there, DON'T use it afterwards.. cast iron does not like being arc welded..
![]() Yes, we threw it in the scrap metal bin. ![]() |
Author: | drmini in aust [ Tue Feb 14, 2012 12:02 pm ] |
Yeah Brett I figured you did, my comment was to warn others why. Cast iron ain't that strong- here an over-lightened iron backplate that let go. OK it was turbo powered... ![]() ![]() |
Author: | MG Rocket [ Tue Feb 14, 2012 4:41 pm ] |
Does the driver still have his right leg? ![]() |
Author: | drmini in aust [ Tue Feb 14, 2012 6:06 pm ] |
Yeah, lucky for him it went out the front. ![]() |
Author: | harry33 [ Tue Feb 14, 2012 8:14 pm ] |
Bugger.. I knew it was all going too smoothly! Thanks for the suggestions for getting it off - I'll try some of them on the weekend. Thanks for the offer Mike, but I think I'll struggle to find the time to drive up there and pick it up. Cheers, Harry |
Author: | Mike_Byron [ Wed Feb 15, 2012 8:14 am ] |
I did an inventory check yesterday - I have at least eight two piece flywheels. If you know someone going past near here let me know and we can work out something in terms of a pickup. Mike |
