It is currently Sun Jul 27, 2025 8:07 am
PostPosted: Wed May 25, 2005 6:40 pm
Well I was driving to work on Tuesday at about 5.20am, pitch black except for the warm glow of the speedo, with the heater on - yes it actually works. listening to the low hum of the 1100 at 100kph (read screaming!) when low and behold the dash started to billow out smoke! holy crapoly I said to myself. Pulled over - did some in the dark investigation to find the ammeter needle bent way over 60amps and I mean BENT and the terminal insulator sort of crispy. Don't know what happened but I really filled em. I turned around, drove home and took the other car to work. I have decided to put a voltmeter instead. Incidentally I got a brand new VDO 150 psi oil pressure gauge from work for free the other day too. Didn't pinch it, we were experimenting with direct reading gauges on the aircaft I work on, but the pilots decided they didn't want engine oil pouring into the cockpit if a line broke - so I asked for it and I got it, I love feebies!
Gig
67 Deluxe - Red and white
69 Deluxe - Sugercane Grey
PostPosted: Wed May 25, 2005 7:53 pm
Been there, done that..
Yep, ammeters are an accident waiting to happen. All the juice (except starter current) goes thru it. All it takes is a bit of body contact or a loose connection and the wiring makes like a welder. :cry:
Voltmeters are safer, more useful devices. Prettier, too! :lol:
 Post subject: Grommet
PostPosted: Wed May 25, 2005 8:16 pm
Yeah....especially if you pass the cables through a firewall with a grommet..look out in years to come :oops: .
Having said that they are OK.......if they are wired in correctly with the correct amperage rated cable and good insulation plus INSULATED COVERS over the terminals....(to avoid embarrassing shorts circuits).
PostPosted: Wed May 25, 2005 9:54 pm
voltmeters connect in parallel
ammeters connect in series
i guess if you apply high school physics to this
and the current is high enough
wow, Mr Moynham was right
Inconspicuously Conspicuous
PostPosted: Wed May 25, 2005 10:00 pm
Smoking is a health hazard :wink:
PostPosted: Wed May 25, 2005 10:02 pm
Worst thing you can do with Lucas electrics is let the smoke out of the wires.. It's `terminal' (pun intended):lol:
PostPosted: Thu May 26, 2005 9:52 am
Yeah that smoke carries the electrons around. If you let enough smoke out then things stop working.
It's worse with transistors and ICs though, you only need to let a little of that Intel (TM) brand smoke out and your computer stops working altogether. :D
And after a capactior pops, it usually has much less capacity.
PostPosted: Thu May 26, 2005 3:03 pm
I thought smoke out the electrics was normal? I remember the fantastic tape deck that was in my Mini when I got it. One day I tried to rewind a tape. Five minutes later I began to wonder why it wasn't working and noticed the smoke coming out the tape slot. Hmmm....
I've got a voltmeter in my car. Very useful with the generator. Oh look, it's reading negative now I turned my headlights on. Maybe the generator is running backwards :)
PostPosted: Thu May 26, 2005 3:10 pm
feebies
i lov feebies too
i lov freebies more tho :P
Nigel Morton/ Team Brickworx
never late in a 998
