Mokesta wrote:
How do you even measure the float let alone adjust it if it is wrong?
assemble the transfer casing and gearbox without the engine, measure the end float and adjust it with different thickness thrust washers.
Mokesta wrote:
Then, when I go to put the clutch cover back on I'd really like the car to last for a little while before it starts leaking oil. What's the secret formula for assembling engine to gearbox and end housings without ending up with leaks? Which is the best product to use? I have a full seal kit from Minispares.
mine usually last at least few months before they start leaking - I use permatex #2
