recommended carby for horsepower (poll) https://www.ausmini.com/forums/viewtopic.php?f=2&t=7565 |
Page 1 of 2 |
Author: | Spaceboy [ Thu May 26, 2005 1:14 am ] |
Post subject: | recommended carby for horsepower (poll) |
i just found this, it confirms what mini tech told me i can't get any more out of my 1& 1/2 inch carby it would be good to have webers on the graph too.. ![]() |
Author: | drmini in aust [ Thu May 26, 2005 6:56 am ] |
I ticked Weber, but it's a Dellorto 45DHLA, Weber clone... ![]() Webers & Dellortos do go OK on smallbores, if you can stand the noise..! ![]() |
Author: | Wolfman [ Thu May 26, 2005 8:36 am ] |
Twin 1 & 1/4 SUs right now, though as soon as I have some spare $ it'll be a Weber |
Author: | Mini Mad [ Thu May 26, 2005 8:57 am ] |
Ditto on the Webber..I have a 40mm dellorto.. on a small bore..or is that bigbore..smallbore..1152cc ![]() I love it...stand the noise!..it's brilliant! ![]() |
Author: | grub [ Thu May 26, 2005 9:06 am ] |
45DHLA Dellorto on mine also. Don't ya love the sound when you get in and fire her up! ![]() Great for those long windy roads where you can hear it at full song. Just need earplugs for those freeway drives! |
Author: | J_A_M [ Thu May 26, 2005 9:21 am ] |
Pops has a standard asthmatic 1 1/4" SU JAM has twin 1 1/4" SU's on LYNX manifold I love the sound of a Weber ![]() BTW, that graph is great. Thanks for sharing it! |
Author: | bnicho [ Thu May 26, 2005 9:23 am ] |
Using a 1 1/2 SU on the van now. I have played with a DGV weber on Geminis etc with good results in the past. So I recently picked up a 32DIR weber progressive downdraft to try, which ios basically a smaller version of a DGV. It came off a 1400-1600cc renault. Choke sizes (fixed) are about right for my modded 1132cc according to Vizard. I just have to find a manifold. So far I have only turned up ones designed for a Nikki carb (stock Jap car carby). Mopoke the Auto-Moke will have a 1 3/4 SU or maybe a set of twin 1 1/4s. Probably the twins for extra torque. ![]() Classic twins ONLY for the Traveller. ![]() |
Author: | cush [ Thu May 26, 2005 9:54 am ] |
my vote puts the 1/2's in front ![]() i'd say i'd be happy with 90hp.... ![]() not much need for more carb.... atkins approved.... |
Author: | Anto [ Thu May 26, 2005 2:57 pm ] |
bnicho wrote: So far I have only turned up ones designed for a Nikki carb (stock Jap car carby).
How different is the mounting of the DGV to a DFM? On our old Gemini we made a conversion bracket to put a 32DFM on the standard Nikki manifold. Problem with the Mini, that conversion bracket would probably add too much height ![]() Anyway, I'm with the Dell'orto crowd. The only thing wrong with them is they're not called 'Weber', and the term Weber, like Cooper S, adds value and speed. Our Gemini with the 32DFM Weber, added fuel, a lot of it, and not much else. Jets? What are they? |
Author: | bnicho [ Thu May 26, 2005 7:06 pm ] |
Anto wrote: bnicho wrote: So far I have only turned up ones designed for a Nikki carb (stock Jap car carby). How different is the mounting of the DGV to a DFM? On our old Gemini we made a conversion bracket to put a 32DFM on the standard Nikki manifold. Problem with the Mini, that conversion bracket would probably add too much height ![]() Yes, that's exactly why I haven't used an adaptor plate. Plus the fact that it would cause restrictions. Used an adptor plate on my Gemini too, but I hogged out the standard inlet to make a better port match with the weber. DGV and DFM have the same mounting spacing. So do most downdraught progressive webers. |
Author: | min13k [ Thu May 26, 2005 7:22 pm ] |
now this is unfair as one car has a 1 1/2 another has a 1 1/4 and the other will have the dello 45 so what do i do makka |
Author: | benjamin [ Thu May 26, 2005 7:40 pm ] |
why is on 1 3/4 su better than twin 1 1/4??? ![]() |
Author: | doogie [ Thu May 26, 2005 7:58 pm ] |
MK 1 Cooper S 1310cc with twin 1 1/2 su's MK 2 Cooper S 1380cc with 45mm weber Mini van 1380 cc with twin 1 1/2 su's 71 Clubman 1100cc with twin 1 1/4's su's Galant VR4 fuel injected with a big turbo hanging of the front ![]() Had to add the last one Doogie |
Author: | drmini in aust [ Thu May 26, 2005 8:10 pm ] |
benjamin wrote: why is on 1 3/4 su better than twin 1 1/4???
![]() Because the motor is only really sucking alternately on the twins. Each pot sees a 1-1/4, whereas with a single (big) carb each pot sees a 1-3/4". That's the theory anyway. Personally I reckon HIF44s are a POS to tune so Barney is getting some nice `old skool' twin HS4s.. Thanks, baracade! ![]() |
Author: | Chris [ Thu May 26, 2005 8:47 pm ] |
Reece Fish is the go. Bloody simple, even simpler than an SU. |
