It is currently Thu Aug 07, 2025 11:16 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Feb 01, 2012 11:05 am
summer is about over, for anyone who has one, how did the ~$90ebay aluminium radiators hold up in the heat?
I notice there are 2 thicknesses available (40mm & 50mm) - interested in feedback on which one you're using, if you're using a 50mm, how well it fitted
50mm - http://www.ebay.com.au/itm/AUSTIN-ROVER ... 3f1052fbda
40mm - http://www.ebay.com.au/itm/AUSTIN-ROVER ... 415f894ee3
PostPosted: Wed Feb 01, 2012 12:19 pm
What summer ? , Simon . :lol:
 Post subject: Alloy Radiators
PostPosted: Wed Feb 01, 2012 12:27 pm
I have used only the 40 mm ones and they are excellent cooling item. Very noticeable difference to a normal radiator. They cool much quicker and keep temp lower. Can't go past them for the price. I would be curious to try a 50 mm one too.
"Let us remove your "SHORTS"
PostPosted: Wed Feb 01, 2012 12:44 pm
been f*cking scorching this side of the mountains
 Post subject: Re: Alloy Radiators
PostPosted: Wed Feb 01, 2012 12:46 pm
any thoughts on whether the extra width would require mods to the radiator shroud?
PostPosted: Wed Feb 01, 2012 12:58 pm
wev`e been using them & fitting them for the last 5x summers
not one problem
they`re sweet
PostPosted: Wed Feb 01, 2012 1:01 pm
not one problem
they`re sweet
thanks Matt - 40 or 50mm?
PostPosted: Wed Feb 01, 2012 2:24 pm
I've been running mine for 2000 kays, 500 back in April / May and the rest since sometime November.
Can't say I've any issues with it at all, though my car runs a normal fan and a thermofan on a relatively stock 1275.
Also hasn't corroded or fallen apart, and it's even still nice and shiney. :D
I'll measure it when I get home.
PostPosted: Wed Feb 01, 2012 3:26 pm
I've not heard a bad thing about these radiators. I've had one sitting in a box ready for the next radiator I pull out for a while... Not used one yet.
PostPosted: Wed Feb 01, 2012 4:10 pm
I can tell you i put these alloy rads through their paces. The only thing that killed it was a rollover.
It performed extremely well, i put it through -3C through to 48C in highway driving speeds of up to 140km/hr. I never had an issue.
As you know, most of my driving was in desert temps, at highway speeds, the only thing i would do if your driving around city is contemplate a blanking plate for the thermostat, if your on the highway this is a BAD idea.
For $95 you cant go wrong. be aware the threads are metric, and sometimes the lugs welded to the sides dont match the brackets. Other than that you cant go wrong.
Id say i did at least 20,000kms with one of these. Try highway 150km/hr for extended period in 48C with a normal RAD, your car wont like you.
PostPosted: Wed Feb 01, 2012 4:41 pm
interesting stuff - they've been around a few years now and I'm curious about how they've been going
PostPosted: Wed Feb 01, 2012 7:26 pm
How awesome is this 8)
I'll be testing mine out with my Moke - I'll probably have a first drive next week at some stage, and being a topless Moke, it'll only be out on the hot days. I'll certainly let you know how I get on.
With the reports on here, looks like it will be a good thing!
PostPosted: Wed Feb 01, 2012 7:28 pm
i got a 2 x 19 mm core , never got over 85 deg c so far
PostPosted: Wed Feb 22, 2012 11:09 pm
Does anyone know where to get one for the 1275LS. eg rearward facing thermostat and heater return line....
Alec
PostPosted: Thu Feb 23, 2012 8:44 am
Has anyone painted one of these black ? It would be interesing to see how much difference it makes to the cooling ,as the black is meant to absorb more heat from the circulating coolant,whereby it can then be taken away by the action of the airflow through the fins
