breathers https://www.ausmini.com/forums/viewtopic.php?f=2&t=75657 |
Page 1 of 2 |
Author: | ricksmini [ Thu Feb 23, 2012 7:15 pm ] |
Post subject: | breathers |
how many breathers should i run on an 1100s engine? |
Author: | simon k [ Thu Feb 23, 2012 7:17 pm ] |
factory was 1, I use two |
Author: | Morris 1100 [ Thu Feb 23, 2012 7:20 pm ] |
I use 1. |
Author: | drmini in aust [ Thu Feb 23, 2012 7:27 pm ] |
I use 1, from the rocker cover to a Toyota PCV valve into the manifold, on both my 1360 and 1412 stroker. I had it on the flywheel housing instead, but the drop gears tossed oil up it on long LH bends if I had `a few' revs up. A well known Nc Mini racer we all know uses none. IMO you only need more than 1 decent breather if you have poor ring sealing. ![]() On my 1360 (now back in the car) I have since added a hose from the rocker cover to the drop gear housing- to help equalize pressure upstairs/downstairs. |
Author: | ricksmini [ Thu Feb 23, 2012 7:33 pm ] |
im using an electric fuel pump so i was wondering if i could put a blanking plate where the mechanical fuel pump goes with a fitting in it to go to a catch can and plum a the rocker cover breather in to it |
Author: | ricksmini [ Thu Feb 23, 2012 7:34 pm ] |
simon k where abouts do you have the pair of breathers |
Author: | drmini in aust [ Thu Feb 23, 2012 7:38 pm ] |
ricksmini wrote: im using an electric fuel pump so i was wondering if i could put a blanking plate where the mechanical fuel pump goes with a fitting in it to go to a catch can and plum a the rocker cover breather in to it
Been there done that. ![]() At 4500 rpm and above the crank and rods will tos HEAPS of oil up it. Don't bother. (MiniMania in USA sells a baffled one, it might work but it ain't cheap). |
Author: | smac [ Fri Feb 24, 2012 5:33 am ] |
http://www.ausmini.com/forums/viewtopic.php?t=71363&postdays=0&postorder=asc&start=15 |
Author: | simon k [ Fri Feb 24, 2012 9:36 am ] |
ricksmini wrote: simon k where abouts do you have the pair of breathers
one on the flywheel housing and one on the rocker cover... can see them here - two into one, then into a little inline PCV and into the inlet manifold |
Author: | DA9jeff [ Fri Feb 24, 2012 1:27 pm ] |
3..... clutch cover/tappet cover/back "door"of block into a 2lt catch can[with drain tap on the bottom.]Starting at the rear offtake...tappet offtake...clutch housing...to catch can on RHS inner guard panel. 1 hose with 3 "T" pieces. |
Author: | drmini in aust [ Fri Feb 24, 2012 1:54 pm ] |
Sorry, ![]() |
Author: | gruhms [ Fri Feb 24, 2012 4:15 pm ] |
drmini in aust wrote: drmini in aust wrote: I use 1, from the rocker cover to a Toyota PCV valve into the manifold, on both my 1360 and 1412 stroker. I had it on the flywheel housing instead, but the drop gears tossed oil up it on long LH bends if I had `a few' revs up. [A well known Nc Mini racer we all know uses none]. IMO you only need more than 1 decent breather if you have poor ring sealing. ![]() I don't like catch tanks on road cars, they make the cabin smelly. But yeah if it was a racer I'd use one. On my 1360 (now back in the car) I have since added a hose from the rocker cover to the drop gear housing- to help equalize pressure upstairs/downstairs. Nice work on quoting your own post. That's awesome. |
Author: | drmini in aust [ Fri Feb 24, 2012 5:30 pm ] |
Sorry double post and I didn't catch it. Had to go in a hurry... ![]() Thanks for posting it all again though, pics and all... ![]() |
Author: | The Duckmeister [ Fri Feb 24, 2012 6:06 pm ] |
I have a single breather, basically the same setup as the good Doctor's. Seems to work well enough. ![]() |
Author: | gruhms [ Sat Feb 25, 2012 9:10 am ] |
drmini in aust wrote: Sorry double post and I didn't catch it. Had to go in a hurry...
![]() Thanks for posting it all again though, pics and all... ![]() Happy to be of service. I'll stop wasting this thread now. |
