It is currently Sun Jul 27, 2025 4:06 pm
 Post subject: Hinge Rebuilding
PostPosted: Wed May 25, 2005 3:14 pm
i've searched and can't find it..
Someone here used to take hinges refurb them and send 'em back.... and i recall it was a decent price..... who is it..?
hmmm....
PostPosted: Wed May 25, 2005 3:47 pm
i have an idea, buy new ones probably cost you the same amount in the end because u have to post it! ...? :roll:
PostPosted: Wed May 25, 2005 4:42 pm
i thought i'd try keeping it in the family, so to speak... :)
PostPosted: Wed May 25, 2005 4:46 pm
Can't you do it yourself? Buy the pins and sleaves and gaskets and a fun day in doors on a rainy day :roll: There is an article somewhere on how to do it.
David L
PostPosted: Wed May 25, 2005 4:47 pm
can't you do it yourself
coz i'm all fumbs..
actually... i CBF :)
PostPosted: Wed May 25, 2005 7:37 pm
And the hinges are damn expensive... From mini car clinic one hinge is $55 exchange...!
So your lookin at $220 for a set, and you still have to give them your old ones....
Life's a garden.... Dig It!
PostPosted: Wed May 25, 2005 7:48 pm
Cushmeister..
Do 'em yourself. The pins are worth $3.93 each, the bushes $6.79.
At Karcraft.
All you need to fit them is... a BFH, a good 1/4" pin punch, a block of wood and a bench drill.
BUT... if hinges are worn bad (as usual) these bushes won't be thick enough, they are only 5/16" OD- so you will then have to get some turned up out of bearing bronze. Make 'em 9.0mm OD.
PostPosted: Thu May 26, 2005 3:21 am
Doc, I still cant get the damn pin out of the chrome hinges - you said there's a trick to it, what is it?
Is there any way of getting the tops of the pins chromed or something to blend in with the hinges?
PostPosted: Thu May 26, 2005 6:53 am
The pins all knock out upwards. Top of pins is splined (ie bigger).
Put hinge assy on a block of hardwood with a groove carved in it (so pin is vertical) then thump 'em out with a BFH and 1/4" pin punch.
re. the chroming- unless you want to completeny chrome them again, the best bet is use a dab of chrome paint on top of pin..
When drilling the middle part for the bush, don't try and clamp it- just sit the lug flat in the vice and carefully drill it out to 5/16" or whatever you made the bush OD. I used a slightly blunted drill so it doesn't cut oversize..
PostPosted: Thu May 26, 2005 9:47 am
can you just paint over the top of the pin? because on a couple of my hinges you can't see the pins...
PostPosted: Thu May 26, 2005 7:44 pm
If they are not Blinged (chrome), just fill and paint 'em. Best do it off the car before refitting. :wink:
