fuel tank photo
https://www.ausmini.com/forums/viewtopic.php?f=2&t=75701
Author:  LAZZA1964 [ Sun Feb 26, 2012 5:04 pm ]
Post subject:  fuel tank photo
ok guys has anyone have a photo of a left hand feul tank ,from around 1962 i believe there is a piece missing from mine i have a brass threaded hole in the bottom and i am thinling maybe it should have something attached at the moment it has a bolt in it help
not sure if someone has made the hole and drilled the thread for the bolt
Author:  michaelb [ Sun Feb 26, 2012 5:27 pm ]
I think you are talking about the drain plug?
It is a bolt with a tube out of the centre
You could also use a bolt if you have lost the original
Author:  simon k [ Sun Feb 26, 2012 7:18 pm ]
DO NOT use a bolt - it won't seal properly
it's one of these, or use a brake bleeder
http://www.minisport.com.au/prod2131.htm
Author:  michaelb [ Sun Feb 26, 2012 7:40 pm ]
That's a good idea, never thought about a brake bleed valve :?
Author:  drmini in aust [ Sun Feb 26, 2012 9:17 pm ]
Thread is 3/8 UNF.
These drains are a PITA, if/when my tank comes out again it'll be getting a brass plug and some Loctite. 8)
Author:  grey 64 [ Mon Feb 27, 2012 8:16 pm ]
My vans tank has a bolt, similar to a sump plug. my sedans have the drain tube. What should the van have?
Author:  simon k [ Mon Feb 27, 2012 9:26 pm ]
bolt - very different setup to a sedan
Author:  LAZZA1964 [ Wed Feb 29, 2012 8:46 pm ]
ok guys thank you very much for youre reply to my q's on fuel tank very much appreciated thanks for the link to the fuel pipe and for the ideas for the other methods.....laz
