It is currently Wed Jul 23, 2025 7:06 pm
PostPosted: Sun Feb 26, 2012 6:00 pm
Decided to push the Mini to get it registered and worry about fitting out the interior later. I have old daggy seats (not the originals that I refurbished the frames and webbing) and figure they would be good enough to sit on but they need tizzing up a bit.
Anyone used Supercrap or similar pull on seat covers in a MIni with low back seats? Any good? Any better than others for a temp job?
I'll also chuck in some cheap rubber floor mats
PostPosted: Sun Feb 26, 2012 6:10 pm
Cant remember where i got mine from, The fit was ok. They are red and black and have sat on the shelf for the last 5 years. You want em? I probably should check they are still around and usable.
PostPosted: Sun Feb 26, 2012 6:16 pm
they are still there, They are one piece and if i remember correctly the back rest section was a little too long so i just gathered the cover to make it presentable/comfortable.
PostPosted: Sun Feb 26, 2012 6:46 pm
Just fronts or back as well?
PostPosted: Sun Feb 26, 2012 7:15 pm
Front only
