It is currently Fri Jul 18, 2025 10:37 pm
PostPosted: Wed Feb 29, 2012 6:35 pm
hey guys, just trying to get a rough idea as to what a few things ive got here are worth to see if their price can be used to fund a new project i have my eye on and appease the wife of its purchase price (its still a mini dont worry)
I have a complete mini K shell, (from my paddock find http://www.ausmini.com/forums/viewtopic.php?t=68705&start=0 with everything but the front running gear. It still has the rear WET subframe, the bad thing is the rust, the floors are pretty much completely gone BUT the rest of the panels have survived relatively well with the only major body rust spot is on the front guard near the door hinge. I had grand idea of doing a welding course and fixing up this car but i havent found the time yet
If my project comes about ill also have a 73 clubman shell up for grabs too. No rust in the floor, a lil in the A-pillar and on the bottom of the pass door. No running gear will be in this one either as ill be using whats in there in the 'project' The shell is straight and sprayed matte black. Will come with a complete interior aswell with seats being in pretty good knick.
Ill also need to part with my custom plates as its not right using them on the project.
They are GTMINI plates for victorian rego.
So there you have it, what do you think each thing would be worth, hopefully enough for what i need
thanks in advance
trent
[/url]
PostPosted: Wed Feb 29, 2012 7:42 pm
I'd say a rust free shell could be worth around $1000 to $2000 for a super straight one with all bolt on panels.
If it's got no floor I'd assume the sills may be a bit rusty to and maybe a hinge panel or so....I think around $250ish. Good pics of all the main rust areas would be a big help.
The 73 is a clubby so you'll probably get $5 if your lucky :lol: , but seriously it could be closer to $500 seeing as it only has a small bit of rust, but again good pics would help.
