Quick Q: removing brazing? https://www.ausmini.com/forums/viewtopic.php?f=2&t=75728 |
Author: | spraycanmansam [ Tue Feb 28, 2012 3:10 pm ] |
Post subject: | Quick Q: removing brazing? |
A quick question - what's the best way to removing factory brazing on a Mini? I've removed the front apron and at the moment have a small half inch high section left from the wheel arch to the bonnet latch panel. I know the apron was spot welded to the wings but there is some brazing on either end (wheel arch and wing-latch panel) which I need to remove nicely. Hope that makes sense. |
Author: | 123grosso [ Tue Feb 28, 2012 3:21 pm ] |
An oxy would be ideal if you could get your hands on one |
Author: | spraycanmansam [ Tue Feb 28, 2012 3:34 pm ] |
An oxy would be perfect, unfortunately I don't have access to one. Would a butane torch or similar get enough heat into it? Or is there another portable tool I could use? |
Author: | drmini in aust [ Tue Feb 28, 2012 3:34 pm ] |
Oxy, or an LPG or butane torch. Hot air gun won't work- too cool. |
Author: | spraycanmansam [ Tue Feb 28, 2012 3:38 pm ] |
This looks like it might fit the bill --- http://www.ebay.com.au/itm/HIGH-TEMP-HI ... 519db597de |
Author: | drmini in aust [ Tue Feb 28, 2012 3:53 pm ] |
spraycanmansam wrote: This looks like it might fit the bill --- http://www.ebay.com.au/itm/HIGH-TEMP-HI ... 519db597de
Might work but I think too small. I was thinking of a plumbers gas torch (Primus, etc). I have oxy/LPG- it'll do anything except fusion weld with steel rod. |
Author: | kiwiinwgtn [ Tue Feb 28, 2012 4:55 pm ] |
I used a small die grinder to get mine off Its a pretty soft weld |
Author: | spraycanmansam [ Tue Feb 28, 2012 5:29 pm ] |
drmini in aust wrote: Might work but I think too small.
I'll let you know how it goes ![]() I got one that pops on top of a butane canister. If it reaches near its advertise 1100C with any luck it will at least soften it up to dig out. |
Author: | drmini in aust [ Tue Feb 28, 2012 5:43 pm ] |
Yeah those sort are OK I have a Ronson one. ![]() Then the Ronson style canisters disappeared and it won't fit current ones. ![]() |
