Clubman heater ducting tube
https://www.ausmini.com/forums/viewtopic.php?f=2&t=7587
Page 1 of 2
Author:  J_A_M [ Fri May 27, 2005 8:46 am ]
Post subject:  Clubman heater ducting tube
Does anyone know where I can get some flexible ducting tube to replace the original Clubman ducting that runs to and from the heater?
I don't care if it is not original, as long as it's flexible and the right diameter.
I went to a very small Mitre 10 yesterday and they had jack s##t.
Author:  drmini in aust [ Fri May 27, 2005 8:53 am ]
Try an aircon place, they use the PVC stuff. :wink:
Author:  Harley [ Fri May 27, 2005 8:58 am ]
Autobarn have different colours and diameters, though the tubing is meant for air intakes in riced up lancers and things.
Author:  J_A_M [ Fri May 27, 2005 9:11 am ]
Harley I bet they charge an arm and leg for that stuff too! Just because it's RICE :twisted:
Author:  Harley [ Fri May 27, 2005 9:13 am ]
Probably, but at least you can colour code it to your liking! :D
It would probably increase air flow through the heater by 1/4 of a horsepower too!
Author:  J_A_M [ Fri May 27, 2005 9:43 am ]
ooohhh...yea!! I'll get RED :wink:
Author:  fuzzy-hair-man [ Fri May 27, 2005 9:48 am ]
Anyone know where to get the really big diameter tubing that goes into the clubby heater from the duct in the front near the grill :?: It sits inside the drivers side guard
Author:  CRU17Y [ Fri May 27, 2005 9:49 am ]
I got it from a place out at St Marys in the industrial area, but can't remeber the name of the place, i got it for my old clubman a couple of years ago, not cheap stuff though.
Give Ivan at mini spares a call he may know the name of the place, as they recomended i get it from there. Colin Dodds may know as well.
Author:  J_A_M [ Fri May 27, 2005 10:17 am ]
yea i know the place...Spectrum Rubber...they supply Clarks with seals etc....
I am after cheap alternatives....not overpriced original stuff :P
Author:  CRU17Y [ Fri May 27, 2005 11:19 am ]
Thats a fair call, at least you have the option.
Author:  Mini Mad [ Fri May 27, 2005 11:45 am ]
I ripped all that tubing out :mrgreen:
Author:  J_A_M [ Fri May 27, 2005 11:58 am ]
:mrgreen:
But I need to plumb it to the windscreen at least...for the demister (for rego) :wink:
Author:  ausminis4u [ Fri May 27, 2005 12:46 pm ]
super crap has it .its behind the assiatance counter in most stores,( it looka about 15 cm long and is black.) expands to about 1 meter in length.
Author:  Simple [ Fri May 27, 2005 12:53 pm ]
For rego??
My demister wasn't working for my last blue slip...(still doesn't work) Don't tell me it has to work for pink slip... Doh
Author:  J_A_M [ Fri May 27, 2005 1:32 pm ]
apparently you need a demister for a bluey in post 71 (?) cars..... in NSW anyway :wink:
