It is currently Sat Jul 26, 2025 9:34 pm
PostPosted: Tue Mar 27, 2012 4:38 pm
Hi all, just a few questions:
- What size are the screws that hold the top plate onto the wiper motor? I lost mine :oops:
- Do I need to use special balls for the pot joints (inner) or can the local bearings shop fix me up?
- What size are the screws that attach the radiator brackets? The po used self tappers - I just don't like the idea of that.
PostPosted: Tue Mar 27, 2012 4:43 pm
balls for Pots are 21/32
sorry i have no idea what thread the wiper ones are
the rad srews can be self-tapers """IF""" you grind the point off them
PostPosted: Wed Mar 28, 2012 10:24 am
Ha, well, the previous owner also gave me a spare radiator which had a mysterious pin-hole in it - using the self-tappers is not a coincidence, I think.
But are the pot joint balls special in any way i.e. are they hardened more or something?
Anyone else have any ideas on the wiper motor screws?
PostPosted: Wed Mar 28, 2012 10:56 am
Not sure if they are hardened
But if you call karkraft in silverwater, Sydney
They should be able to post some to you, I know they stock them.
Ask for Tim, he knows what he's talking about.
Don't think they would carry the screws though..
You're so square
Baby I don't care
PostPosted: Wed Mar 28, 2012 11:15 am
Pot joint balls are hardened ballrace steel.
They are bigger than CV ones (which are 9/16").
If Kc don't have them, any bearing shop would (or can get), but you need to measure the diameter or take a sample.
For the proper screws, try Mini King. He might have the pot joint balls too.
PostPosted: Wed Mar 28, 2012 12:35 pm
yes they`re hard like bearing balls are all meant to be
& are 21/32nds" in size (as i said above) 21/32
PostPosted: Wed Mar 28, 2012 6:27 pm
The other option is to buy a new pot joint as they are not that expensive
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Mar 29, 2012 11:47 pm
This looks like it solves your screw problem, I think they're correct:
http://www.ebay.com.au/itm/Lucas-DR2-DR ... _500wt_898
Comes with grommets too!
You're so square
Baby I don't care
PostPosted: Fri Mar 30, 2012 8:09 am
Thanks adamstuart, but I am after the other screws - the ones that hold the top plate onto the body of the wiper motor. Does anyone know of a tool I can use to measure it?
Oh, and on the cv balls, I ended up going to SWB bearings in Hobart, and they ordered one for me - $2. The main reason I go into shops as opposed to buying online is customer service, and I would recommend them to anyone in tas.
