fuel pump https://www.ausmini.com/forums/viewtopic.php?f=2&t=75948 |
Author: | ricksmini [ Wed Mar 14, 2012 4:59 pm ] |
Post subject: | fuel pump |
hi all just a small question. Where do people or how do you guys mount a facet silver top pump like what minisport sells. Cheers |
Author: | michaelb [ Wed Mar 14, 2012 6:27 pm ] |
I managed to mount mine vertically on the subframe near where the Cooper s pumps are mounted My car is not a daily driver so not too worried about water damage although it is up out of the way, just. |
Author: | poeee [ Wed Mar 14, 2012 7:05 pm ] |
I mounted mine on the rear subframe (on the horizontal face) under the tank. I used two holes that were already there, made up a right angled bracket which I mounted to the subframe with exhaust cotton reel mounts, and bolted the pump to that on a 45deg angle as per the pump recomendations. |
Author: | ricksmini [ Wed Mar 14, 2012 7:11 pm ] |
ok i think ive got you any photos by any chance |
Author: | drmini in aust [ Wed Mar 14, 2012 7:13 pm ] |
poeee wrote: I mounted mine on the rear subframe (on the horizontal face) under the tank. I used two holes that were already there, made up a right angled bracket which I mounted to the subframe with exhaust cotton reel mounts, and bolted the pump to that on a 45deg angle as per the pump recomendations.
I used the facet square one, it bolts straight onto a Mini centre zorst mount. Drill a 5/16" hole through the subby web and fit a nyloc nut, all done. |
Author: | ricksmini [ Wed Mar 14, 2012 7:24 pm ] |
thanks fellas i will have a fiddle |
Author: | poeee [ Wed Mar 14, 2012 7:30 pm ] |
Mount it on a 45 deg angle like I mentioned and like the doc's photo if you can (really no reason why you shouldn't be able to). |
