Bits of metal in my clutch housing
https://www.ausmini.com/forums/viewtopic.php?f=2&t=75990
Author:  harry33 [ Fri Mar 16, 2012 10:02 pm ]
Post subject:  Bits of metal in my clutch housing
So I finally got round to getting my flywheel off (which was surprisingly painless after I tapped the new threads), and I found all these fragments of .. something .. sitting at the bottom of the clutch housing:
(I'm just holding it there for scale.. I have no idea whether or not it's meant to live somewhere around there)
Does anybody have any idea where these might have come from?
Harry
Author:  haze blue 850 [ Fri Mar 16, 2012 10:57 pm ]
HARRY33
(I'm responding so I get a reminder)
I gotta know too!!!!!!!
When I stripped my 850 for the rebuild, I had almost the same bits. I asked around and no one could tell me???
I had enough bits to make a circle, but couldn't find where it broke off. I eventually put the new clutch in and everything seems alright.??
Watching with interest,,,,,////
Alex.
Author:  MiniVLT [ Fri Mar 16, 2012 11:37 pm ]
I'm only guessing, but surely someone hasn't tried to "shim" the primary gear end float??
Cheers Shane
Author:  smac [ Sat Mar 17, 2012 6:01 am ]
Cheers Shane
Correct, actually not uncommon.
Author:  simon k [ Sat Mar 17, 2012 12:11 pm ]
smac wrote:
Cheers Shane
nasty!! I've never heard of that being done!
that said, I have a modified primary gear in my engine (has been there for the last 12 years) and we had to put dobs of weld on the C washer (then surface ground flat) to push the other bit closer to the bush
Author:  smac [ Sun Mar 18, 2012 2:57 pm ]
Seen a couple, and had one myself for a while, no worries at all. The shim should be a full circle though, I really can't see how one gets torn up and spat out - I'd suggest there's something else going on to cause that (i.e something wobbling that should be).
Slightly off topic - also saw a master seal today installed backwards - also no problems. Bit of oil in there, but no clutch slip! A series have their issues, but in their own way they're also pretty damned forgiving!
Author:  drmini in aust [ Sun Mar 18, 2012 3:32 pm ]
Shimming is not a great idea there.
I have built up the outer washer with nickel bronze then machined to size in years past, that works well.
But usually you can fix it with new parts- bronze inner thrust washer, outer stepped washer, and C-washer.
Author:  smac [ Sun Mar 18, 2012 5:22 pm ]
Agree, not a great idea.
But infinitely more accessible to the home mechanic than some other options. 8)
