How much to re-kit a clutch master cylinder? https://www.ausmini.com/forums/viewtopic.php?f=2&t=75993 |
Author: | Kennomini [ Fri Mar 16, 2012 11:36 pm ] |
Post subject: | How much to re-kit a clutch master cylinder? |
I have a tin clutch MC and I got quoted $250 to re-sleve and build an old MC. Also got a price on just a rebuild kit and that was $45. New ones on ebay are 90 odd bucks or $155 for the tin type. Why on earth would I re-sleve it when the new one is $100 cheaper. Dose anyone here know if they can be re-sleved cheaper or if the kits can be brought for less than $45. |
Author: | TheMiniMan [ Sat Mar 17, 2012 1:37 am ] |
Kenno, i`m not gunna torque money, but a resleaved "Tin" tanked cyl is more thanb the others cause they need to de-solder the tank,,, sleave it & then re-solder the tank,,, time consuming the other plastic res types are cheaper to sleave |
Author: | Timbo [ Sat Mar 17, 2012 5:20 am ] |
The guy who re-sleeved mine quoted about $80 just to do the re-sleeving. I took the reservoir off and re-soldered it myself. I did the re-assembly and the kit was a lot less than $45 from Somerford. Tim |
Author: | GT mowog [ Sat Mar 17, 2012 6:50 am ] |
Author: | goodie [ Sat Mar 17, 2012 7:31 am ] |
i have just had a .7" M/C stainless steel sleeved to .75" for $205 . That price included s/s sleeve ,making a new piston to suit , fitting a new kit & postage , bench testing , had it back within a week . This was for a plastic tank type m/c . |
Author: | drmini in aust [ Sat Mar 17, 2012 9:53 am ] |
A resleeved (with SS or brass) original MC won't get corrosion inside like the standard ones can- whether new or old! Also they still look period correct. For those that care. ![]() |
Author: | Goldbrocade_62 [ Sat Mar 17, 2012 8:51 pm ] |
TheMiniMan wrote: Kenno, i`m not gunna torque money, but a resleaved "Tin" tanked cyl is more thanb the others cause they need to de-solder the tank,,, sleave it & then re-solder the tank,,, time consuming
the other plastic res types are cheaper to sleave The tin tanks I've had done the drill 2 holes in the tank then solder plugs on the tank |
