It is currently Fri Aug 15, 2025 10:11 pm
PostPosted: Fri Mar 16, 2012 11:36 pm
I have a tin clutch MC and I got quoted $250 to re-sleve and build an old MC. Also got a price on just a rebuild kit and that was $45.
New ones on ebay are 90 odd bucks or $155 for the tin type.
Why on earth would I re-sleve it when the new one is $100 cheaper.
Dose anyone here know if they can be re-sleved cheaper or if the kits can be brought for less than $45.
PostPosted: Sat Mar 17, 2012 1:37 am
Kenno, i`m not gunna torque money, but a resleaved "Tin" tanked cyl is more thanb the others cause they need to de-solder the tank,,, sleave it & then re-solder the tank,,, time consuming
the other plastic res types are cheaper to sleave
PostPosted: Sat Mar 17, 2012 5:20 am
The guy who re-sleeved mine quoted about $80 just to do the re-sleeving. I took the reservoir off and re-soldered it myself. I did the re-assembly and the kit was a lot less than $45 from Somerford.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sat Mar 17, 2012 6:50 am
Mods rock!
:?: $45 for a kit :?: Jezz....the last one I got was $7 and I winged about that!
PostPosted: Sat Mar 17, 2012 7:31 am
i have just had a .7" M/C stainless steel sleeved to .75" for $205 .
That price included s/s sleeve ,making a new piston to suit , fitting a new kit & postage ,
bench testing , had it back within a week .
This was for a plastic tank type m/c .
PostPosted: Sat Mar 17, 2012 9:53 am
A resleeved (with SS or brass) original MC won't get corrosion inside like the standard ones can- whether new or old!
Also they still look period correct. For those that care. :wink:
PostPosted: Sat Mar 17, 2012 8:51 pm
The tin tanks I've had done the drill 2 holes in the tank then solder plugs on the tank
Users browsing this forum: No registered users and 176 guests
