It is currently Fri Aug 15, 2025 8:53 am
 Post subject: Rod change seal question
PostPosted: Mon Mar 19, 2012 8:21 am
So is there some sort of lip that the rod change seals sits against to stop it going through into the gearbox?
If I push another 47 seals in there am I going to fill my diff up...?
PostPosted: Mon Mar 19, 2012 8:27 am
there is normally enough room for 2 seals, sometimes you can even fit 3 seals in there
but it will stop at the interspool lock,,, it can`t go further than that
i have awesome gearshift seal "Bushes" for sale tho if you`d like to not have any leaks from there
PostPosted: Mon Mar 19, 2012 8:58 am
It's already got a Rover-type alloy bush in there. I'd swap it with one of yours but it's a PITA to get the old one out!
I put a new seal in yesterday, and found I could fit two seals in, so I wanted to make sure I hadn't just pushed the alloy bush into the diff :lol:
PostPosted: Mon Mar 19, 2012 1:13 pm
Nope as Matt says the interlock spool will stop it.
In the old days it was easy to just bung another seal in when it leaked. 2 fit fine and 3 sometimes. :lol:
Users browsing this forum: No registered users and 271 guests
