Rod change seal question https://www.ausmini.com/forums/viewtopic.php?f=2&t=76021 |
Author: | Anto [ Mon Mar 19, 2012 8:21 am ] |
Post subject: | Rod change seal question |
So is there some sort of lip that the rod change seals sits against to stop it going through into the gearbox? If I push another 47 seals in there am I going to fill my diff up...? |
Author: | TheMiniMan [ Mon Mar 19, 2012 8:27 am ] |
there is normally enough room for 2 seals, sometimes you can even fit 3 seals in there but it will stop at the interspool lock,,, it can`t go further than that i have awesome gearshift seal "Bushes" for sale tho if you`d like to not have any leaks from there |
Author: | Anto [ Mon Mar 19, 2012 8:58 am ] |
It's already got a Rover-type alloy bush in there. I'd swap it with one of yours but it's a PITA to get the old one out! I put a new seal in yesterday, and found I could fit two seals in, so I wanted to make sure I hadn't just pushed the alloy bush into the diff ![]() |
Author: | drmini in aust [ Mon Mar 19, 2012 1:13 pm ] |
Nope as Matt says the interlock spool will stop it. In the old days it was easy to just bung another seal in when it leaked. 2 fit fine and 3 sometimes. ![]() |
