It is currently Wed Jul 30, 2025 12:42 pm
 Post subject: Timing Degrees?????
PostPosted: Tue Mar 20, 2012 9:41 pm
Hi guys, what Deg should my Cooper S be set at??
Its a 1310 with a works cam and stage 3 head??
regular Cooper S dizzy, and twin su carbs.
Any idea? :? :?
PostPosted: Tue Mar 20, 2012 10:19 pm
start where the workshop manual says to start - 5 degrees?
I used to find it was always "about right" if I advanced the distributor to where it idled the fastest, then go backwards a little bit to where it sounded nice. After that I'd go and drive up my usual test hill and listen for pinging. Eventually I got a timing light and discovered that I was just about spot on...
PostPosted: Tue Mar 20, 2012 10:50 pm
2 deg before TDC
PostPosted: Tue Mar 20, 2012 11:14 pm
thanks guys!!
PostPosted: Wed Mar 21, 2012 4:43 am
my cooper is set at 2 deg
1967 Morris mini Deluxe
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
1982 Jaguar XJ6 series 3
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Wed Mar 21, 2012 9:54 pm
30 degrees BTDC @ 4500 RPM
That's what mine is on 1330 big head 296 cam 98 octane fuel
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Wed Mar 21, 2012 10:06 pm
I gave up setting timing static or at idle years ago.
Most 1275s on 98 unleaded run best at around 30° total advance @ 4000 rpm and up.
It's the middle of the ballpark. Works for my 1412 stroker.
Some need slightly less, but my 1360 (282 cam and big head) needs 38° total because a PO bathtubbed the head. :shock:
Users browsing this forum: No registered users and 69 guests
