Timing Degrees????? https://www.ausmini.com/forums/viewtopic.php?f=2&t=76042 |
Author: | brett [ Tue Mar 20, 2012 9:41 pm ] |
Post subject: | Timing Degrees????? |
Hi guys, what Deg should my Cooper S be set at?? Its a 1310 with a works cam and stage 3 head?? regular Cooper S dizzy, and twin su carbs. Any idea? ![]() ![]() |
Author: | simon k [ Tue Mar 20, 2012 10:19 pm ] |
start where the workshop manual says to start - 5 degrees? I used to find it was always "about right" if I advanced the distributor to where it idled the fastest, then go backwards a little bit to where it sounded nice. After that I'd go and drive up my usual test hill and listen for pinging. Eventually I got a timing light and discovered that I was just about spot on... |
Author: | TheMiniMan [ Tue Mar 20, 2012 10:50 pm ] |
2 deg before TDC |
Author: | brett [ Tue Mar 20, 2012 11:14 pm ] |
thanks guys!! |
Author: | 1970cooper [ Wed Mar 21, 2012 4:43 am ] |
my cooper is set at 2 deg |
Author: | Beanie [ Wed Mar 21, 2012 9:54 pm ] |
30 degrees BTDC @ 4500 RPM That's what mine is on 1330 big head 296 cam 98 octane fuel |
Author: | drmini in aust [ Wed Mar 21, 2012 10:06 pm ] |
I gave up setting timing static or at idle years ago. Most 1275s on 98 unleaded run best at around 30° total advance @ 4000 rpm and up. It's the middle of the ballpark. Works for my 1412 stroker. Some need slightly less, but my 1360 (282 cam and big head) needs 38° total because a PO bathtubbed the head. ![]() |
