Urgent help!!!!!! https://www.ausmini.com/forums/viewtopic.php?f=2&t=76072 |
Author: | Cooper_Matrikon [ Fri Mar 23, 2012 9:24 am ] |
Post subject: | Urgent help!!!!!! |
Hi all. I'm sitting in Barney and we are going nowhere. Two days ago we were cruising along and then we came to a stop almost like running out if fuel. Five minutes later he started an ran beautifully. New coil on last night thinking it was spark related. Now I've got a new GREEN light coming on under the 80 on the speedo. Wtf????? Running a pulsar dizzy so could it be a condenser? I managed to restart briefly but it sounded like it was running on three. Now it just cranks over. Any ideas? |
Author: | drmini in aust [ Fri Mar 23, 2012 10:43 am ] |
No condenser in a Pulsar electronic dizzy. As said on phone, I would start by spraying dizzy cap inside and out with WD40, wipe dry and spray (lightly) again. If Pulsar dizzys fail (I've only seen 1 do this) it's the module, and you get no sparkys at all. The Hitachi module is pretty bulletproof compared to others. |
Author: | Mike Montgomery [ Fri Mar 23, 2012 11:30 am ] |
Sounds like mine when my fuel pump ate itself. Is your filter clean and holding fuel? |
Author: | drmini in aust [ Fri Mar 23, 2012 11:43 am ] |
Mike Montgomery wrote: Sounds like mine when my fuel pump ate itself. Is your filter clean and holding fuel?
Evan told me fuel delivery was tested and is fine. |
Author: | Cooper_Matrikon [ Fri Mar 23, 2012 1:29 pm ] |
Well, I'm back. Turns out it was simply water in the dizzy. Ahem. ![]() |
Author: | drmini in aust [ Fri Mar 23, 2012 1:32 pm ] |
Author: | Mini Mad [ Fri Mar 23, 2012 1:58 pm ] |
What'd the green light have to do with it? |
Author: | Cooper_Matrikon [ Fri Mar 23, 2012 2:00 pm ] |
Green light came on and stayed on once I attached an errant wire here: ![]() |
Author: | goodie [ Fri Mar 23, 2012 8:48 pm ] |
Cooper_Matrikon wrote: Well, I'm back. Turns out it was simply water in the dizzy. Ahem.
![]() I thought these dizzies were pretty much bullet proof in the wet ! ![]() I have one of these dizzies modded , to go in my car , but after driving through a bloody big storm , with a sh!t load of running water across the road , my car didn't even look like stopping ( but i was waiting for it ) , i might have to re- consider fitting it . ![]() |
Author: | drmini in aust [ Fri Mar 23, 2012 9:44 pm ] |
Goodie, They are bulletproof, but not if there is any moisture in there. Although there is a rubber seal under the cap (if still there), there is a vent provided in some caps. I remove and spray mine with WD40 once a year, never had any trouble since. I can hose it whilst it's running- without any cover over the dizzy. ![]() [edit] I use an unvented Bosch GH617 cap. |
Author: | Fiji [ Sat Mar 24, 2012 5:20 am ] |
drmini in aust wrote: I remove and spray mine with WD40 once a year, never had any trouble since. I can hose it whilst it's running- without any cover over the dizzy.
![]() ![]() Love to see that . If its waterproof it's bulletproof. |
Author: | Tombo [ Sat Mar 24, 2012 6:37 am ] |
I run one of those red bull coils too ![]() On a mini i recently brought back to life i put on a new cap and bosch plug leads, i assured the owner that it will be fine in the wet by hosing down the plugs leads and dizzy while running, didn't miss a beat. A good cap and leads are a must. |
Author: | Fiji [ Sat Mar 24, 2012 6:40 am ] |
Paint engine red & get a red bull coil.... 5 HP at least ![]() |
