Dellorto Accelerator Pump adjustment https://www.ausmini.com/forums/viewtopic.php?f=2&t=76108 |
Author: | Anto [ Mon Mar 26, 2012 10:07 am ] |
Post subject: | Dellorto Accelerator Pump adjustment |
Can anybody give me a run down of how the accelerator pump rod on a Dellorto DHLA should be set? This information is curiously absent from my Tuning manual, so I've been setting it by trial and error. I'd be interested to know whether I can determine if my accelerator pump jet is too big/small based on where the pump rod is adjusted to get it running right. ![]() |
Author: | drmini in aust [ Mon Mar 26, 2012 10:21 am ] |
The more you screw the nuts on the rod, the more effective pump stroke you get. I think mine has around 6mm length of thread sticking out, I'll try and measure it. What size pump jets are you running- I think mine are 50. |
Author: | Anto [ Mon Mar 26, 2012 10:30 am ] |
I think I'm running 55 jets but I'll need to double check The way I had it set up there wasn't a great deal of pump stroke. When I increased the pump stroke (by quite a bit, admittedly) it ran really bad. I reckon I would be better to run smaller pump jets with a greater stroke on the pump rod, so I might experiment on that one. |
Author: | drmini in aust [ Mon Mar 26, 2012 11:42 am ] |
Regardless of the pump jet size, IMO you can't stomp on the throttle at idle and expect it not to bog down. Even on my 1412... ![]() Once it's around 2500 rpm+, different story. People that want to use the throttle like a light switch should stick to SUs... or maybe fit injection. ![]() |
Author: | Anto [ Mon Mar 26, 2012 11:57 am ] |
Bog down? With a 286 cam and a Dellorto? Never ![]() Car is running okay in general, but uses a lot of petrol. Getting it running well is one thing, getting it running well with (reasonable) economy is another ![]() |
Author: | drmini in aust [ Mon Mar 26, 2012 1:14 pm ] |
Don't be afraid to lean off the main jet size a bit for general running about. It helps economy a lot. I use 168s for general use (170s were NLA), 175 or 180 for dyno runs etc. [edit] I have 36mm chokes in it. |
Author: | Anto [ Mon Mar 26, 2012 1:46 pm ] |
I'm currently running 34 chokes with 155 main jets. Thinking of dropping it back to 150s or 145s. If it still goes hard with the smaller jets then I'm happy ![]() |
Author: | drmini in aust [ Mon Mar 26, 2012 2:34 pm ] |
Anto wrote: I'm currently running 34 chokes with 155 main jets. Thinking of dropping it back to 150s or 145s. If it still goes hard with the smaller jets then I'm happy
![]() I ran 34 chokes and 145 mains for years in my 1310S. Should be fine. Air correctors are 180, always seems to be about right in a Dellorto. [edit] Anto, re the rod adjustment, it feels to be about 5 or 6mm but I cannot see the bugger in the car.. ![]() |
