What head is this? https://www.ausmini.com/forums/viewtopic.php?f=2&t=76112 |
Author: | CARTER_GT [ Mon Mar 26, 2012 12:13 pm ] |
Post subject: | What head is this? |
Hi all stupid me cant find any numbers to work out what this head is. It reads: 12A 1456 heres a pic ![]() Cheers, Steve |
Author: | smac [ Mon Mar 26, 2012 12:22 pm ] |
Stock 850/998 head isn't it? Edit: yep... http://www.minimania.com/web/SCatagory/ ... ticleV.cfm |
Author: | CARTER_GT [ Mon Mar 26, 2012 12:42 pm ] |
nothing special then ![]() Thanks smac ![]() |
Author: | Anto [ Mon Mar 26, 2012 12:53 pm ] |
CARTER_GT wrote: nothing special then
![]() Depends... With slightly bigger inlet valves and some porting it may well be just as good as a 12G202 head, as per stock 1098 ![]() |
Author: | CARTER_GT [ Mon Mar 26, 2012 12:55 pm ] |
Anto wrote: CARTER_GT wrote: nothing special then ![]() Depends... With slightly bigger inlet valves and some porting it may well be just as good as a 12G202 head, as per stock 1098 ![]() Ohh.. ![]() |
Author: | drmini in aust [ Mon Mar 26, 2012 1:11 pm ] |
You can port them out & fit big valves just like you can with a 202, but there's more metal to remove. Way back when they were all we had, I used to start by sticking a 1-1/16" drill down the inlet ports. ![]() |
Author: | CARTER_GT [ Mon Mar 26, 2012 1:48 pm ] |
drmini in aust wrote: You can port them out & fit big valves just like you can with a 202, but there's more metal to remove.
Way back when they were all we had, I used to start by sticking a 1-1/16" drill down the inlet ports. ![]() Im keen to do this ![]() |
Author: | drmini in aust [ Mon Mar 26, 2012 2:42 pm ] |
Stop before you get to the Y bit (aka a bifurcation). Then blend the ports back in with a die grinder. Works good with 202 or 295 inlet valves. Make sure you drill it straight in a big bench drill or a milling machine- there is only about 1-1/8" of space between the edges of the 2 pushrod holes. If you eff it up don't worry, the world is full or 12A1456 heads. ![]() |
Author: | smac [ Tue Mar 27, 2012 5:41 am ] |
What does an unmolested 202 head sell for in aus these days? |
Author: | drmini in aust [ Tue Mar 27, 2012 6:34 am ] |
~$50 for a 202 needing reco, $100 up for a good one complete, with good valves still. 295s bring a lot more, but they tend to be cracked more often than 202s from my observations. |
Author: | smac [ Tue Mar 27, 2012 7:36 am ] |
Ya I have a rusty old 295 sitting here but I'm not sure it's even worth getting it cleaned up and tested.....pretty pitted. |
