A+ Block to replace A series https://www.ausmini.com/forums/viewtopic.php?f=2&t=76122 |
Author: | bluewhitecoopers1968 [ Tue Mar 27, 2012 5:23 am ] |
Post subject: | A+ Block to replace A series |
Hey all, I'm looking at fitting an A+ 1275 block/crank to replace a damaged A series block, I'm gonna just fit the remote gearbox, pre-verto clutch and head from A series, which I still have. Will it swap ok or are there any issues with doing this? Thanks, Richard. |
Author: | drmini in aust [ Tue Mar 27, 2012 6:37 am ] |
It'll all be fine. ![]() |
Author: | GT mowog [ Tue Mar 27, 2012 11:36 am ] |
Sometimes the rear No. 3 Main Bearing Cap bolt might just kiss the the Gearbox, not always, but check. Do a trial assembly without gaskets and the half moon seal first. Your old dissy won't swap straight over. You'll need to change the drive dog and shorten the shaft a whisker, or get an A+ dissy. |
Author: | CARTER_GT [ Tue Mar 27, 2012 12:18 pm ] |
And as well as what GT said you need to run a different oil dipstick ![]() ![]() ![]() ![]() |
Author: | GT mowog [ Tue Mar 27, 2012 1:52 pm ] |
CARTER_GT wrote: And as well as what GT said you need to run a different oil dipstick
![]() ![]() ![]() ![]() Good point. Any UK Dipstick (A or A+) up to about 96 works. The Ozzy made flat ones won't. |
Author: | simon k [ Tue Mar 27, 2012 3:19 pm ] |
![]() excuse my ignorance - what's the difference? |
Author: | drmini in aust [ Tue Mar 27, 2012 6:06 pm ] |
They go straight into the block, there is no guide tube. [edit] you can make an early round one fit, but the stop washer isn't in quite the right spot (I can't remember if too high or low). |
Author: | bluewhitecoopers1968 [ Tue Mar 27, 2012 6:24 pm ] |
Thanks for the reply's guys, will keep this all in mind. Cheers, Richard. |
