Wiper motor screws and pot bearings https://www.ausmini.com/forums/viewtopic.php?f=2&t=76132 |
Author: | Irish Yobbo [ Tue Mar 27, 2012 4:38 pm ] |
Post subject: | Wiper motor screws and pot bearings |
Hi all, just a few questions: - What size are the screws that hold the top plate onto the wiper motor? I lost mine ![]() - Do I need to use special balls for the pot joints (inner) or can the local bearings shop fix me up? - What size are the screws that attach the radiator brackets? The po used self tappers - I just don't like the idea of that. |
Author: | TheMiniMan [ Tue Mar 27, 2012 4:43 pm ] |
balls for Pots are 21/32 sorry i have no idea what thread the wiper ones are the rad srews can be self-tapers """IF""" you grind the point off them ![]() |
Author: | Irish Yobbo [ Wed Mar 28, 2012 10:24 am ] |
Ha, well, the previous owner also gave me a spare radiator which had a mysterious pin-hole in it - using the self-tappers is not a coincidence, I think. But are the pot joint balls special in any way i.e. are they hardened more or something? Anyone else have any ideas on the wiper motor screws? |
Author: | adamstuart [ Wed Mar 28, 2012 10:56 am ] |
Not sure if they are hardened But if you call karkraft in silverwater, Sydney They should be able to post some to you, I know they stock them. Ask for Tim, he knows what he's talking about. Don't think they would carry the screws though.. |
Author: | drmini in aust [ Wed Mar 28, 2012 11:15 am ] |
Pot joint balls are hardened ballrace steel. They are bigger than CV ones (which are 9/16"). If Kc don't have them, any bearing shop would (or can get), but you need to measure the diameter or take a sample. For the proper screws, try Mini King. He might have the pot joint balls too. |
Author: | TheMiniMan [ Wed Mar 28, 2012 12:35 pm ] |
yes they`re hard like bearing balls are all meant to be & are 21/32nds" in size (as i said above) 21/32 |
Author: | michaelb [ Wed Mar 28, 2012 6:27 pm ] |
The other option is to buy a new pot joint as they are not that expensive |
Author: | adamstuart [ Thu Mar 29, 2012 11:47 pm ] |
This looks like it solves your screw problem, I think they're correct: http://www.ebay.com.au/itm/Lucas-DR2-DR ... _500wt_898 Comes with grommets too! |
Author: | Irish Yobbo [ Fri Mar 30, 2012 8:09 am ] |
adamstuart wrote: This looks like it solves your screw problem, I think they're correct:
http://www.ebay.com.au/itm/Lucas-DR2-DR ... _500wt_898 Comes with grommets too! Thanks adamstuart, but I am after the other screws - the ones that hold the top plate onto the body of the wiper motor. Does anyone know of a tool I can use to measure it? Oh, and on the cv balls, I ended up going to SWB bearings in Hobart, and they ordered one for me - $2. The main reason I go into shops as opposed to buying online is customer service, and I would recommend them to anyone in tas. |
