It is currently Sun Jul 20, 2025 4:12 am
PostPosted: Sun Apr 01, 2012 4:35 pm
Fitting the radiator to the 1275 and the top radiator bracket looks wrong. It looks too short as the radiator sits at an angle, coming in at the top. It also doesn't sit properly on the thermostat housing. It only has one mounting hole for the thermostat housing where others i have seen have 2 holes.
Could someone measure the bracket for me from the rear thermostat housing stud to the end of the bracket against the radiator. (For a roundnose).
May have to buy a new bracket.
Thanks in advance.
PostPosted: Sun Apr 01, 2012 6:08 pm
Mods rock!
1275's used a different bracket to the small bore engines. I think Mini Sport SA have them or you could make one.
