carb needle for an HS6 on 1098 https://www.ausmini.com/forums/viewtopic.php?f=2&t=76198 |
Page 1 of 2 |
Author: | drmini in aust [ Sun Apr 01, 2012 1:17 pm ] |
Post subject: | carb needle for an HS6 on 1098 |
Vizard is no help, so what would be an HS6 needle to start with on a 1098? (I used an OA6 on the 1412.. I do have some TW needles- a lot leaner). Engine specs (was Barney's old motor): 1098 +.040 mild cam (dunno what `tis, Mini Kingdom fitted it a zillion years back) modified 202 head, std rockers HS6 carb with Ramflo filter Minispares or Minisport 1-3/4 manifold LCB and 1-3/4 zorst system Thanks guys. ![]() |
Author: | TheMiniMan [ Sun Apr 01, 2012 1:32 pm ] |
hee hee,,, honestly, try another OA6 you`ll be surprised the little donks only suck what they need so it`ll probly be fine with an OA6 as well ![]() |
Author: | drmini in aust [ Sun Apr 01, 2012 1:38 pm ] |
Thanks Matt. I can use my needle to try. Next question: Would the HS6 be better than his existing HS4? Or a waste of time... ![]() |
Author: | TheMiniMan [ Sun Apr 01, 2012 2:58 pm ] |
yeah, it`d be alright,,, maybe chuck some 1.5 rockers on it & make sure the manifold is all nice & flowy without any hard/sharp edges etc & it should be sweet |
Author: | mattsmadmini [ Sun Apr 01, 2012 5:22 pm ] |
is this Kev's attempt at an april fools? ![]() |
Author: | Morris 1100 [ Sun Apr 01, 2012 6:03 pm ] |
mattsmadmini wrote: is this Kev's attempt at an april fools?
Author: | GT mowog [ Sun Apr 01, 2012 6:09 pm ] |
Post subject: | Re: carb needle for an HS6 on 1098 |
drmini in aust wrote: Vizard is no help, so what would be an HS6 needle to start with on a 1098?
Thanks guys. ![]() If this is not an April 1 Day prank, there is a Very Good reason why it's not listed in Vizards Book ![]() |
Author: | drmini in aust [ Sun Apr 01, 2012 6:40 pm ] |
GT mowog wrote: drmini in aust wrote: Vizard is no help, so what would be an HS6 needle to start with on a 1098? Thanks guys. ![]() If this is not an April 1 Day prank, there is a Very Good reason why it's not listed in Vizards Book ![]() ... the reason probably is UK only got about 15x 1098 Minis (mostly Clubby Travellers)? ![]() No, not April Fools, I am serious. People do put HIF44s on tuned 1098s, but we would rather use an HS6 because: a. We have one, b. They don't suffer from the O-rings rotting in unleaded fuel, c. I have NFI how to tune an HIF, I'm strictly olde skool. ![]() d. They look sikker than a common HS4. |
Author: | TK [ Mon Apr 02, 2012 7:57 am ] |
I put a HS6 on a warm 998, no problems at all and it went very well. |
Author: | drmini in aust [ Mon Apr 02, 2012 8:15 am ] |
TK wrote: I put a HS6 on a warm 998, no problems at all and it went very well.
Thanks Ty. Needle was??? |
Author: | TK [ Mon Apr 02, 2012 10:04 am ] |
OA6 of course. ![]() |
Author: | drmini in aust [ Mon Apr 02, 2012 12:26 pm ] |
TK wrote: OA6 of course.
![]() ![]() Red spring??? |
Author: | TheMiniMan [ Mon Apr 02, 2012 12:32 pm ] |
drmini in aust wrote: TK wrote: OA6 of course. ![]() ![]() Red spring??? hee hee,,, yep... i would & just for the sake of playing with people`s heads... i once fitted a single 1&3/4 SU onto a 4.5 litre studebaker & ran an OA6 needle & it ran like a charm, perfect plug colour & the customer was soooooo in love with it we did the same with a 4.5 litre daimler years before that i also ran my 4.4litre alloy V8 powered Kombi ute with a single 1&3/4 su & same needle but 2x yellow springs wound together & then chopped to allow the piston to reach max height,,, also ran like an absolute charm with perfect plugs colours... However, i must admit that when i swaped out the std cam for a warm one , i had to stuff with the needle quite a fair bit to get it right... damn thing did massive wheel-stands ![]() Yet --> & how`s this grab ya--> i run twin 1&3/4 Sus on my mini ![]() ![]() ![]() ![]() i reckon the same set-up would run a lawnmower perfectly ![]() (well ok, maybe not twins on the mower tho ![]() |
Author: | drmini in aust [ Mon Apr 02, 2012 12:35 pm ] |
If I recall correctly, this OA6 needle was used on the Austin Healey 3000 motor. Versatile, ain't it. ![]() |
Author: | TheMiniMan [ Mon Apr 02, 2012 12:36 pm ] |
drmini in aust wrote: If I recall correctly, this OA6 needle was used on the Austin Healey 3000 motor.
Versatile, ain't it. ![]() that`s "exactly" the word for it Doc |
