fuel tank help
https://www.ausmini.com/forums/viewtopic.php?f=2&t=76204
Author:  mini4350 [ Sun Apr 01, 2012 10:07 pm ]
Post subject:  fuel tank help
im looking at getting a bigger fuel tank made for my 78 leyland van
does anyone know of someone or lead me in the right direction. Im in Perth but will go almost anywhere.
Author:  Harley [ Sun Apr 01, 2012 10:09 pm ]
How big do you want to go?
If you fit an LS / Rover tank and a RH tank you'll have 60 litres.
Easy to do and cheaper than getting a tank made.
Author:  Davo111 [ Sun Apr 01, 2012 10:12 pm ]
Why not look at a rover tank, they hold 35 litres i think, they should be easy to get hold of
Author:  Morris 1100 [ Sun Apr 01, 2012 10:17 pm ]
Van.
Author:  Harley [ Sun Apr 01, 2012 10:19 pm ]
Dammit, thought it sounded too easy you're right. How'd I miss that?
:lol:
Author:  mini4350 [ Sun Apr 01, 2012 10:20 pm ]
i was thinking of getting one made the same as the original but bigger to take advantage of all of the original space, and i will divert the exhaust to give me access to the whole of the rear under section of the car
Author:  drmini in aust [ Sun Apr 01, 2012 10:22 pm ]
The wife's 77 van is getting a 20L jerry can in the back. I might paint it to match the decor... :lol:
Author:  IndigoBlueCooperS [ Sun Apr 01, 2012 10:33 pm ]
Had a Mini many years ago where the fuel tank was fitted within the subframe area. This would work with a van. Not sure how the exhaust was run. The tank was from an old Holden or Morris Minor - not sure which, but it was a good fit. Will try and find an old photo.
Author:  Bubbacluby [ Sun Apr 01, 2012 10:39 pm ]
I have a mate here in town who has done this to his mini van (amongst other mods) i could go and take a photo of it except its out of town at a panel beaters.
He had someone weld them up from aluminium. Sorry i cant go and take photos. but from memory he had to make it an odd shape for the exhaust.
Author:  mini4350 [ Sun Apr 01, 2012 10:43 pm ]
its more finding someone who will make it for me due to the legal issues
Author:  Harley [ Sun Apr 01, 2012 10:44 pm ]
Check out some of the engine conversion threads. I'm sure I've seen a van or two that had tanks from other cars adapted into the back.
Author:  TheMiniMan [ Mon Apr 02, 2012 8:57 am ]
you could try the spridget (sprite/midget) tanks, i think we used to use those to fit inside the rear subframe years ago
Author:  adamstuart [ Mon Apr 02, 2012 9:49 am ]
Export mokes have tanks in the rear subby too.
Author:  ALPINE MOKE [ Mon Apr 02, 2012 10:13 am ]
Post subject:  FUEL TANK VAN
I had an alloy tank made to fit in the area rear of the battery in a van
You will need a pipe 1/2'' ID from the main tank to the alloy one and a breather fitted to the alloy tank
Mine holds about 25 L, when you fill the main the other tank also fills
