Fuel sender rubber seal https://www.ausmini.com/forums/viewtopic.php?f=2&t=76211 |
Author: | grey 64 [ Mon Apr 02, 2012 6:28 pm ] |
Post subject: | Fuel sender rubber seal |
should any sealant be used on the rubber seal? I jammed a new one in and it leaks ![]() |
Author: | GT mowog [ Mon Apr 02, 2012 6:52 pm ] |
I've only ever fitted them dry. I don't think there was any sealant used from the factory. What I have noticed though is that they are a prime place for rust and that would make it leak. |
Author: | drmini in aust [ Mon Apr 02, 2012 7:20 pm ] |
I found a smear of rubber grease helps fitment, and it won't harm the rubber. |
Author: | michaelb [ Mon Apr 02, 2012 9:10 pm ] |
I had this problem a few weeks ago and luckily the tank was not full ![]() I had fitted a new rubber and new sender and it was leaking I removed both and made sure the surface in the tank was clean and I also knocked the tabs, that the sealing ring press against, up so the we're more vertical so the sealing ring was able to clamp down tight onto the sender. I think this was the problem because when I tried to clamp tighten the sealing ring it "popped" out from one of the tabs and I suddenly had a bigger leak than original ![]() So far all good now ![]() |
