Top arm question.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=76264
Author:  Frank Mathews [ Thu Apr 05, 2012 10:05 pm ]
Post subject:  Top arm question.
Was reading thru the manual with regards to changing the needle rollers in the top arms. It states that they should be fitted into the arm a certain depth. Does anyone know what this magic figure is??? Any help appreciated. :D
Author:  TheMiniMan [ Thu Apr 05, 2012 10:42 pm ]
push them in untill they butt on the shoulder inside
Author:  Frank Mathews [ Thu Apr 05, 2012 10:51 pm ]
Thanks. The ones I pulled out were only just inside the arm, maybe .005" below the surface. I guess it's not that important then where they sit??
Author:  TheMiniMan [ Fri Apr 06, 2012 9:00 am ]
yeah it does matter-->
there`s a shoulder "INSIDE" that they butt against (the inner end of the bearings would butt against this shoulder).
that should then place the outer edge of them just inside the ends of the arms
Author:  Frank Mathews [ Fri Apr 06, 2012 10:53 am ]
Thanks again mini man. Now that they're clean I can see the inner step. :roll: cheers.
Author:  TheMiniMan [ Fri Apr 06, 2012 11:28 am ]
you`re most welcome
& happy Easter :-)
