Opininon of parts value? https://www.ausmini.com/forums/viewtopic.php?f=2&t=76270 |
Author: | Bubbacluby [ Fri Apr 06, 2012 11:22 am ] |
Post subject: | Opininon of parts value? |
I know something is worth what ever someon will pay but wanted an estimate of current market value of the following group of parts * 1100 S 12G940 head * Mk 1 cooper s block * Mk 1 cooper s rods * Cooper s crank (not sure size or journals) So it is assembled (as in short motor) but has not been rebuilt, it is as it was when pulled out of car |
Author: | TheMiniMan [ Fri Apr 06, 2012 11:26 am ] |
easilly $2000 if it`s all in either good condition or at least in a "re-conditionable" state (in my books) & to give you a bit of a break-down on it all--> head $300+ depending Block $600 - $700 (easilly, maybe more) Rods a definate $200+ Crank between $500 & $1000 depending then there are things like the cam shaft & push rods & rockers, dbl row timing gear set etc etc etc ??? all would be there as well yeah??? |
Author: | Bubbacluby [ Fri Apr 06, 2012 11:33 am ] |
Thanks Matt im not sure about the timing chanin and gears, The cam may possibly be there. But he was asking $750 ![]() |
Author: | TheMiniMan [ Fri Apr 06, 2012 11:44 am ] |
i`ll buy it right now ![]() |
Author: | Bubbacluby [ Fri Apr 06, 2012 11:55 am ] |
Thanks Matt, im seeing him at 2pm. Cheers for the advice |
Author: | Mike_Byron [ Fri Apr 06, 2012 1:02 pm ] |
Make sure you get the 1275 idler gear with it - its different to a small block idler gear in that a 1275 crank is stepped and the idler gear is bushed to fit it. Mike |
Author: | drmini in aust [ Fri Apr 06, 2012 2:45 pm ] |
Mike_Byron wrote: Make sure you get the 1275 idler gear with it - its different to a small block idler gear in that a 1275 crank is stepped and the idler gear is bushed to fit it.
Mike That'd be the primary gear, not the idler... ![]() And try it on the crank- the front bushes wear. If worn, the easiest fix is a Minispares floating silicon bronze bush. No machining needed (once you get the old bush out) it just slips in there. Available here from most Mini places, or direct from Minispares UK. |
Author: | brett [ Fri Apr 06, 2012 4:05 pm ] |
Bummer I will be down that way the next week or so. |
Author: | low n blown [ Fri Apr 06, 2012 6:46 pm ] |
Value depends largely on the condition though. If the crank is cracked that value changes to $0. If the head is cracked that also drops to $SFA, and if the block is more than 120thou over it is also worth $SFA. At least know what you are buying before you hand over your cash. The rods are usually pretty good, although early Mk1 rods can have a few problems. |
Author: | Mike_Byron [ Fri Apr 06, 2012 7:52 pm ] |
drmini in aust wrote: Mike_Byron wrote: Make sure you get the 1275 idler gear with it - its different to a small block idler gear in that a 1275 crank is stepped and the idler gear is bushed to fit it. Mike That'd be the primary gear, not the idler... ![]() That would be right of course - its what happens when you type and talk to visitors at the same time. They were an idle lot of visistors and somehow it transposed. Mike |
Author: | Bubbacluby [ Fri Apr 06, 2012 8:26 pm ] |
low'n blown wrote: Value depends largely on the condition though. If the crank is cracked that value changes to $0. If the head is cracked that also drops to $SFA, and if the block is more than 120thou over it is also worth $SFA. At least know what you are buying before you hand over your cash. The rods are usually pretty good, although early Mk1 rods can have a few problems.
Yeah thats true, went and had a chat to him and im gunna get all the parts checked out by mini mate before i buy them, he said thats ok. So if trashed im not getting them. Cheers everyone |
