speedo question https://www.ausmini.com/forums/viewtopic.php?f=2&t=76277 |
Author: | davestar62 [ Fri Apr 06, 2012 4:32 pm ] |
Post subject: | speedo question |
Hi all! the speedo in my mini has not worked at all since I bought it 2 years ago. This hasnt been much of a problem (i could judge 60kph from the tacho), untill I got a speeding fine the other week ![]() everything else (fuel gauge, HB light and night time light) works on it however. Is it just a case of replacing the speedo cable to get it working again? |
Author: | brett [ Fri Apr 06, 2012 4:52 pm ] |
OK, remove the speedo, and take it for a drive, if you see the center moving, that means your speedo is stuffed. if its not, it could be the cable stuffed, or the pinion in the gearbox is stuffed |
