Anyone know who has seal kits for MK1 Lockheed servos? https://www.ausmini.com/forums/viewtopic.php?f=2&t=76321 |
Page 1 of 2 |
Author: | Wombat [ Wed Apr 11, 2012 7:16 am ] |
Check Hydroboost in Melbourne http://www.hydroboost.com.au/ It's where I got mine. |
Author: | Mick [ Wed Apr 11, 2012 9:07 am ] |
Also here (You have the Lockheed type 5½ ): http://www.jlspares.co.uk/sealkits.htm If it has been rebuilt and just sitting idle, then you will probably only need the Hydraulic Seal Kit and Gaskets You can get by without the main large diaphragm. It will be simply buggered or not. Before you order the parts it would be a good idea to take the back end apart (simple) to check the condition of the chrome Piston Push Rod. If the hard chrome plating on the pushrod has lifted you will need to pick up another one. Don't take apart the air control valve if you don't have to. It is delicate and expensive! Lift the cover and check the condition, don't try and peel it back from the lower cover. It will probably tear. |
Author: | isleblue65 [ Wed Apr 11, 2012 1:15 pm ] |
Mick wrote: Also here (You have the Lockheed type 5½ ):
http://www.jlspares.co.uk/sealkits.htm If it has been rebuilt and just sitting idle, then you will probably only need the Hydraulic Seal Kit and Gaskets Thanks! I contacted JLspares and they didn't give me prices except for their full rebuild process. I wasn't sure what servo I had, so this helps a lot! Hydroboost hasn't returned e-mails. I'll get the seal kit from JL as that's what the seller said I would only need as well. |
Author: | Wombat [ Wed Apr 11, 2012 1:47 pm ] |
I think Hydroboost is a part time second business - sometimes takes a while to reply. Phone might be quicker. |
Author: | isleblue65 [ Wed Apr 11, 2012 2:33 pm ] |
Wombat wrote: I think Hydroboost is a part time second business - sometimes takes a while to reply. Phone might be quicker.
I might just do this. Have to coordinate the time difference from the left coast USA ![]() By the way Mick, how do you know it is a 5 1/2 before I order parts? |
Author: | Wombat [ Wed Apr 11, 2012 2:41 pm ] |
isleblue65 wrote: Wombat wrote: I might just do this. Have to coordinate the time difference from the left coast USA ![]() Ooops - didn't pick that up |
Author: | drmini in aust [ Wed Apr 11, 2012 4:41 pm ] |
isleblue65 wrote: Wombat wrote: I think Hydroboost is a part time second business - sometimes takes a while to reply. Phone might be quicker. I might just do this. Have to coordinate the time difference from the left coast USA ![]() By the way Mick, how do you know it is a 5 1/2 before I order parts? Hi Craig, It was known back then as a Lockheed 5-1/2". We never got the later Lockheed ones over here, our Mk2s got a `PBR' VH44J (Made in Oz) instead. |
Author: | AJ [ Wed Apr 11, 2012 6:39 pm ] |
The replica boosters are no longer available ..... |
Author: | AJ [ Wed Apr 11, 2012 6:47 pm ] |
isleblue65 wrote: Mick wrote: Also here (You have the Lockheed type 5½ ): http://www.jlspares.co.uk/sealkits.htm If it has been rebuilt and just sitting idle, then you will probably only need the Hydraulic Seal Kit and Gaskets Thanks! I contacted JLspares and they didn't give me prices except for their full rebuild process. I wasn't sure what servo I had, so this helps a lot! Hydroboost hasn't returned e-mails.. Hydroboost seem very reluctant to do Lockheed boosters , I have contacted them a few times but no joy ........ |
Author: | Wombat [ Wed Apr 11, 2012 8:47 pm ] |
AJ wrote: isleblue65 wrote: Mick wrote: Also here (You have the Lockheed type 5½ ): http://www.jlspares.co.uk/sealkits.htm If it has been rebuilt and just sitting idle, then you will probably only need the Hydraulic Seal Kit and Gaskets Thanks! I contacted JLspares and they didn't give me prices except for their full rebuild process. I wasn't sure what servo I had, so this helps a lot! Hydroboost hasn't returned e-mails.. Hydroboost seem very reluctant to do Lockheed boosters , I have contacted them a few times but no joy ........ From the Hydroboost Home page: **** Although you can enquire or order via Email it is better to telephone Terry so you can discuss your needs in greater detail. |
Author: | AJ [ Wed Apr 11, 2012 9:04 pm ] |
I have been told that NBS Brake Supplies in Victoria ,do a very good job restoring to better than new condition . I am going to send my MK1 booster to them shortly ,when I get it off the car .Will let you know how it goes http://www.nbsbrakesupplies.com.au/serv ... vices.html |
Author: | isleblue65 [ Wed Apr 11, 2012 9:28 pm ] |
drmini in aust wrote: isleblue65 wrote: By the way Mick, how do you know it is a 5 1/2 before I order parts? Hi Craig, It was known back then as a Lockheed 5-1/2". We never got the later Lockheed ones over here, our Mk2s got a `PBR' VH44J (Made in Oz) instead. Hi Kevin, as this booster is here in the US and I don't know if it came off a British built Mini, Australian or-? is there another way to tell what it is? Does the 5 1/2 refer to the length of the cast cylinder body? I don't know how to identify these things just by looking:? I think I'm going to take the gamble and buy it and get the seals and see how it goes. If it turns out I need to have it sleeved, there are some California sources that can do this, and I wouldn't have to ship it overseas. |
Author: | drmini in aust [ Wed Apr 11, 2012 10:06 pm ] |
5-1/2" is the diameter of the servo piston. ![]() There was also a 6" Lockheed (later I think?) but it wasn't used on these cars. |
Author: | brett [ Wed Apr 11, 2012 10:38 pm ] |
AJ wrote: The replica boosters are no longer available .....
I got mine only a couple of months ago....... A mini restoration specialist in Somerford has some left ![]() |
