It is currently Wed Aug 20, 2025 11:52 am
 Post subject: EFI Fuel Filter?
PostPosted: Mon Apr 16, 2012 1:08 pm
Just thinking, I will need a fuel filter for my Mini. I am going fuel injected so it needs to be a high pressure one. Can anyone recomend an "off the shelf" filter kit available here in Australia?
PostPosted: Mon Apr 16, 2012 1:18 pm
Just go into an auto store and find anything designed for 'push through' fuel injection with a 5/16" size barb on it. The stock rover one is a fairly standard size common to lots of Japanese cars.
PostPosted: Mon Apr 16, 2012 9:34 pm
I'm filtering before the EFI pump, so just using a normal $5 filter from wherever.
Why bother filtering after the pump, if there's any crap in the fuel, you don't want it getting into the pump anyway....
PostPosted: Mon Apr 16, 2012 9:56 pm
I'm using an EFI tank so pump is inside...
PostPosted: Mon Apr 16, 2012 9:57 pm
I think you need a finer filter to protect injectors. Too fine to suck through without cavitating in the pump so you pre-filter the big chunks and post filter the small stuff. I have a rover EFI filter and mount... goes to shed to photo...
PostPosted: Mon Apr 16, 2012 10:09 pm
Back from the shed:
PostPosted: Mon Apr 16, 2012 10:33 pm
fair enough - f*ck knows where I'd fit one of them....
PostPosted: Tue Apr 17, 2012 7:41 am
Mokesta wrote:
Back from the shed:
That's what I want... where can I get something like that on this side of the equator? I have copper fuel pipe and can crimp the ends so "all" I need is the filter and end fittings...
PostPosted: Tue Apr 17, 2012 8:22 am
It's not a complex as it looks in this shot.
The actual filter is just a plain metal cylinder with a threaded inlet/outlet on each end.
The photo shows it inside the thin black metal bracket that wraps around it and bolts it to the body.
PostPosted: Tue Apr 17, 2012 8:42 am
This would be a Z200 fuel filter. Looks similar in dimensions to the rover fuel filter, but with barbed ends. Available at any auto parts store for cheap.
Andrew
Users browsing this forum: Bing [Bot] and 78 guests
