Saad tachometer wiring diagram?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=76369
Author:  clovus [ Sat Apr 14, 2012 5:54 pm ]
Post subject:  Saad tachometer wiring diagram?
Hi all,
I have a saas tachometer but have lost the wiring diagram. Does anyone have a copy? I searched google and the forums but am unsure if the saas one is different to other gauges.
I'm guessing white is for instrument lighting, black for a ground, red and green I'd rather not guess and cause problems.
Cheers in advance
Author:  simon k [ Sat Apr 14, 2012 6:06 pm ]
it's pretty hard to cause problems with them - green is going to be to the coil, red will be ignition 12v
does it light up with 12v on the white & earth on the black?
Author:  clovus [ Sun Apr 15, 2012 2:49 pm ]
Thanks Simon,
I wired the black to the chassis earth, white to the battery, red to the positive terminal on the coil and the green to the negative terminal.
Cheers for the help
Clovus
