It is currently Tue Aug 19, 2025 1:01 pm
PostPosted: Sat Apr 14, 2012 11:08 pm
I have stripped that pesky little pinch bolt that holds the column to the rack
Is it a special bolt, i remember reading some where that the length of the shaft was important
or can i use a cap screw
PostPosted: Sat Apr 14, 2012 11:13 pm
IMO, the stock bolt should have been 5/16" not 1/4". I fit a grade 12 cap head bolt and HT nut. The original was 1-3/8" long.
PostPosted: Sat Apr 14, 2012 11:20 pm
Thanks
That's what I was thinking of doing as well
I will use a 5/16 drill bit as a guide and see I can get it to fit through the clamp
Ta
Bernard
PostPosted: Sun Apr 15, 2012 8:16 pm
The original bolt was only a Grade 5. A Grade 8 or better 1/4" UNF bolt (and nut) should be fine...
Users browsing this forum: No registered users and 313 guests
