EFI Fuel Filter? https://www.ausmini.com/forums/viewtopic.php?f=2&t=76398 |
Author: | Trog [ Mon Apr 16, 2012 1:08 pm ] |
Post subject: | EFI Fuel Filter? |
Just thinking, I will need a fuel filter for my Mini. I am going fuel injected so it needs to be a high pressure one. Can anyone recomend an "off the shelf" filter kit available here in Australia? |
Author: | Harley [ Mon Apr 16, 2012 1:18 pm ] |
Just go into an auto store and find anything designed for 'push through' fuel injection with a 5/16" size barb on it. The stock rover one is a fairly standard size common to lots of Japanese cars. |
Author: | simon k [ Mon Apr 16, 2012 9:34 pm ] |
I'm filtering before the EFI pump, so just using a normal $5 filter from wherever. Why bother filtering after the pump, if there's any crap in the fuel, you don't want it getting into the pump anyway.... |
Author: | Trog [ Mon Apr 16, 2012 9:56 pm ] |
simon k wrote: I'm filtering before the EFI pump, so just using a normal $5 filter from wherever.
Why bother filtering after the pump, if there's any crap in the fuel, you don't want it getting into the pump anyway.... I'm using an EFI tank so pump is inside... |
Author: | Mokesta [ Mon Apr 16, 2012 9:57 pm ] |
Why bother filtering after the pump, if there's any crap in the fuel, you don't want it getting into the pump anyway.... I think you need a finer filter to protect injectors. Too fine to suck through without cavitating in the pump so you pre-filter the big chunks and post filter the small stuff. I have a rover EFI filter and mount... goes to shed to photo... |
Author: | Mokesta [ Mon Apr 16, 2012 10:09 pm ] |
Back from the shed: ![]() |
Author: | simon k [ Mon Apr 16, 2012 10:33 pm ] |
Mokesta wrote: I think you need a finer filter to protect injectors. Too fine to suck through without cavitating in the pump so you pre-filter the big chunks and post filter the small stuff. I have a rover EFI filter and mount... goes to shed to photo...
fair enough - f*ck knows where I'd fit one of them.... |
Author: | Trog [ Tue Apr 17, 2012 7:41 am ] |
Mokesta wrote: Back from the shed:
![]() That's what I want... where can I get something like that on this side of the equator? I have copper fuel pipe and can crimp the ends so "all" I need is the filter and end fittings... |
Author: | VicMini13 [ Tue Apr 17, 2012 8:22 am ] |
It's not a complex as it looks in this shot. The actual filter is just a plain metal cylinder with a threaded inlet/outlet on each end. The photo shows it inside the thin black metal bracket that wraps around it and bolts it to the body. |
Author: | afh001 [ Tue Apr 17, 2012 8:42 am ] |
Harley wrote: Just go into an auto store and find anything designed for 'push through' fuel injection with a 5/16" size barb on it.
This would be a Z200 fuel filter. Looks similar in dimensions to the rover fuel filter, but with barbed ends. Available at any auto parts store for cheap. Andrew |
